Yet another type of M291 needed, I think...
I'm working on a macro where I want to put a non-blocking M291 message on the screen that will be cancelled when another M291 is issued. My super-simple example is below
M291 S1 T0 P"This is the first message, with S=1, T=0" echo "got here" M291 S1 T5 P"This is the second message, with S=1, T=5" The first M291 puts up a non-blocking message with no timeout. And I see the echo command displayed while the message is still on screen.
When I finally close the first message, the second is displayed for the requested 5 seconds.
I think the behavior happening is that the gcode execution stream is non-blocking, but the message display stream remains blocking. If that makes sense.
The behavior I expected (and would like) is for the second message to force closure of the first message.
Maybe this is a case where I should have an M292 in my macro, just before line 3?
@mikeabuilder said in Yet another type of M291 needed, I think...:
try it?
Answering my own query, but asking if I'm doing something risky.
This behaves as I want, using m292 to
M291 S1 T0 P"This is the first message, with S=1, T=0" echo "got here" g4 s5 m292 p0 M291 S1 T5 P"This is the second message, with S=1, T=1" I added the M292 just before the new message.
@T3P3Tony - thanks for the vote of encouragement to give it a go. If there are not obvious issues to using the M292, I'm good to go.
@mikeabuilder not sure how it might interact with DWC cancelling a message box, thats one for @chrishamm
Now if I cancel the message box myself, I get an error when the M292 runs. I'll look for a way to add an if to see if there is an existing message box.
The object model has an array "messages" but it is not available in standalone mode.
@mikeabuilder check the OM, i think there maybe something in there. Also have a look at the 3.5 release notes as M291 behaviour has changed.
From the 3.5 Beta2 changelog:
- M291 messages are now queued. When a M291 command is executed the new message is added to the end of the queue, and any non-blocking messages already in the queue have their timeouts reduced to 1 second. If the queue is already full then the oldest non-blocking message is cancelled, or if there are no non-blocking messages in the queue, the oldest message is cancelled. The queue length is currently 8 messages.
In my test initial three line macro, it does not seem like the first non-blocking message is getting it's timeout reduced to 1. I tried changing the timeout on the first message to T=9999, and the timeout does get reduced to 1, so I have my solution. I'll just set the first timeout to a very long time. Maybe a non-blocking timeout t=0 is a special case for the timeout length reduction thing.
@mikeabuilder
You can check if the messagebox array is null. If it's not null, then a message box is being displayed.if state.messageBox!=null M292 ; cancel message box
