    DuetEthernet not starting up correctly
    • c4tn1pundefined
      c4tn1p
      Hi Everyone,
      My new Rostock Max DuetEthernet system has been working great, until last week when I accidentally damaged my delta smart effector while changing a nozzle. I ordered a new one and installed it carefully, double checking all the connections, grounding myself while working, and making sure not to damage the traces. However, when I turned my system back on, the web interface on my DuetEthernet is no longer available. I have been tinkering with it a while but everything I have tried has been frustratingly ineffective; I still have no idea what the problem is. Here are my observations so far:
      • The lights on the ethernet port do not turn on, ever. Tried USB power only in addition to (and separately from) full 24v power from my mean well supply, and tested different ethernet cables and ports on my main switch. No lights on the ethernet port under any circumstances; it appears to be turned off, although the IC on the ethernet board does heat up.
      • Several other LEDs on the main board light up, including the 3.3v light, the 5v light, and the red LEDs by the stepper drivers. The "diag" LED (what is this?) also comes on sometimes.
      • I reinstalled the fimware using the SAM-BA programmer after m997 S0 yielded the error "Error: Firmware binary "DuetEthernetFirmware.bin" not found" despite the fact that the file was triple-checked to be the right version, with the right name, located in /sys on the SD card. M115 yields the output:
        FIRMWARE_NAME: RepRapFirmware for Duet Ethernet FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet Ethernet 1.0 FIRMWARE_DATE: 2017-09-01
      • I tried a couple of versions of config.g, including the one that was working fine before I replaced my effector platform, and a new one generated by the RepRap configurator. Commenting out network settings has no effect one way or the other. My current config.g file is quoted below.
      • M552 with no args states that networking is disabled. M552 S1 causes the serial console output to hang for about 10 seconds, then the board apparently restarts with no explanation, without the network ever coming up before or afterward.
      • According to my router, the board is not sending DHCP requests, nor does setting a static IP in config.g and in the router's reserved address space have any effect.
      I'm worried that my networking module has somehow died… This is frustrating; I really like this board, so much so that I've quickly become dependent on it... so I need it to work! Any help is much appreciated.
      [[language]]
      ; Configuration file for Duet Ethernet (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Mon Nov 20 2017 18:16:38 GMT-0500 (Eastern Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R144.8 L291.06 B140 H310 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P1 X0 Y0 Z0 H10 F120 T3600 ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 R100 S20 ; Define mesh grid
      M350 X32 Y32 Z32 E16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z80 E476.5 ; Set steps per mm
      M566 X900 Y900 Z900 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X21000 Y21000 Z21000 E1200 ; Set maximum speeds (mm/min)
      M201 X750 Y750 Z750 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1200 I60 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M301 H0 S0.90 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S150 ; Set temperature limit for heater 0 to 150C
      M305 P1 T100000 B4138 C0 R4700 X202 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 202
      M143 H1 S350 ; Set temperature limit for heater 1 to 350C
      M563 P0 D0 H1 ; Define tool 0
      M550 PDUET3D_0 ; Set machine name
      M540 P7A:A1:E5:68:5B:B9 ; Set MAC address
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F10 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F100 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F100 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      T0 ; Select first tool
        It does sound that your networking module has died. Please contact your supplier.
        • c4tn1pundefined
          c4tn1p
          Thanks dc42 for confirming what I was afraid was the case. Have you seen this happen before? Any suggestions for how to safeguard against it happening again? Either way, thanks more than I can say for the work you have put into this excellent project.
