Smart effector sensitivity
  • undefined
    mfoltz
    I recently got the smart effector, and i am loving it. One question though, I am trying to put a script in my slicer to turn the sensitivity down (20-30) for my pre print calibration run and then turn it up (60-70) for the pring. I used the g code for adjusting the sensitivity from the wiki but it does not seem to adjust it. Where in the interface could I look to see what the sensitivity is set to? I have noticed in settings>machine properties there is a window for z probe that has a trigger value that always says 100. is this the sensitivity and if so why does it never change even when I input the g code M672 S105:50:205 as the wiki says?
    • undefined
      sungod3k
      Why do you want to change the sensitivity? Do you get errors during the print that stem from it?
      and the wiki describes a blinking pattern of the LED that confirm if your are on the default or if it accepted your custom value.
      Personally, i also though i needed to change the sensitivity but after 2-3 test I went back to default and havent had an issues since.
      Cheers
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
      1 out of 2
