    Config.g issue
    Firmware installation
    2.1k
    • sjason1377undefined
      sjason1377 Banned
      Hello I have been working for a month trying to config the printer I built. I posted before mechanic reasons for my setup, but in this post I just want to address the files. I can asure you everything is in order hardware wise. it at least moved around before. I am place my setup info for review. I'm at the end of my road and the whole things gettin scrap real soon. all extrenal drives X is on lcd conn 10, Y is on lcd 11, Z E0 E1 E2 are on the expansion breakout board. Z5 E0:6 E1:8 E2. boards at 24 volts drives at 24 volt. opt iso multi channel for to lcd connector to x,y exp board does it for the other 4 drive. This is something i'm missing in the firmware. I can m80/81 the axt on control fans switch relays verify check ends stops, but no motoring. I read 4.37 volt on dir pins with no drop jogging dir. no pulses being produced be duet ethernet board. I check them with my Tektronix 1052b, and trust me theres no pulsing not even noise. dir is surpising stable at 4.3703 vdc. this board only works with the onboard equipment.Making a button do what you want
      ; Configuration file for Duet Ethernet (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Mon Oct 23 2017 18:51:17 GMT-0400 (Eastern Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M208 X295 Y295 Z207 S0 ; Set axis maxima
      M574 X2 Y1 Z1 S0 ; Define active high microswitches
      M558 P5 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to BLTOUCH, the axes for which it is used and the probe + travel speeds
      G31 P50 X50 Y10 Z.7 ; Set Z probe trigger value, offset and trigger height
      M557 X35:200 Y35:200 S20 ; Define mesh grid
      M557 R78
      ; tools
      M563 PO D6:8:9 H1 F2
      G10 P0 S0 R0 X0 Y0
      M569 P0 S1 R0 T1.5 ; Drive 10 goes forwards
      M569 P1 S1 R1 T1.5 ; Drive 11 goes forwards
      M569 P2 S1 R1 T1.5 ; Drive 5 goes forwards
      M569 P3 S1 R1 T1.5 ; Drive 6 goes forwards
      M569 P4 S1 R1 T1.5 ; Drive 8 goes forwards
      M569 P5 S1 R1 T1.5 ; Drive 9 goes forwards
      m584 X10 Y11 Z5 E6:8:9
      M350 X32 Y32 Z32 E32:32:32 I1 ; Configure microstepping with interpolation
      M92 X200 Y200 Z6400 E160:160:160 ; Set steps per mm
      M566 X900 Y900 Z12 E120:120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X4000 Y4000 Z180 E1200:1200:1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250:250:250 ; Set accelerations (mm/s^2)
      M906 X0 Y0 Z0 E0:0:0 ; Set motor currents (mA)
      M84 S0 ; Disable motor idle current reduction
      M143 S260 ; Set maximum heater temperature to 260C
      M307 H7 A1 C1 D1
      M563 P0 D0 H1 ; Define tool 0
      M550 P kathryn printer ; Set machine name
      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
      M552 P0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        sjason1377 Banned
        next
        Idle
        kathryn printer
        Tools / Heaters
        Control All
        Tool Heater Current Active Standby
        Tool 0
        T0
        Heater 1
        active 23.8 °C
        Tool 127
        T127
        Heater 1
        active 23.8 °C
        Bed
        Heater 0
        off 23.9 °C
        Temperature Chart
        0
        50
        100
        150
        200
        250
        Machine Status
        Head Position X Y Z
        0.0 0.0 0.00
        Extruder Drives Drive 1 Drive 2
        0.0 0.0
        Sensors Vin Z-Probe
        24.4 V 1000
        Machine Control
        Print Status
        G-Code Console
        G-Code Files
        Macros
        Filaments
        Settings
        General
        User Interface
        List Items
        System Editor
        Machine Properties
        Tools
        Drive Configuration
        Drive Endstop hit Minimum Maximum InstantDv Max Speed Acceleration Motor Current
        0 No 0 mm 295 mm 15 mm/s 66.67 mm/s 500 mm/s² 0 mA
        1 No 0 mm 295 mm 15 mm/s 66.67 mm/s 500 mm/s² 0 mA
        2 No 0 mm 207 mm 0.2 mm/s 3 mm/s 250 mm/s² 0 mA
        3 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        4 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        5 No n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        6 No n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        7 No n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        8 No n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        9 No n/a n/a 2 mm/s 20 mm/s 250 mm/s² 0 mA
        Z-Probe
        Type:
        Digital Switch (5)
        Trigger Height:
        0.7 mm
        Trigger Value:
        50
        Other
        Geometry:
        Cartesian
        Motor Idle Current Factor:
        30%
        Motor Idle Timeout:
        never
        why are the drive still list in the default way?
          sjason1377 Banned
          Idle
          kathryn printer
          Tools / Heaters
          Control All
          Tool 0
          T0
          Heater 1
          active 23.9 °C
          Tool 127
          T127
          Heater 1
          active 23.9 °C
          Bed
          Heater 0
          off 23.8 °C
          Temperature Chart
          0
          50
          100
          150
          200
          250
          Machine Status
          Head Position X Y Z
          0.0 0.0 0.00
          0.0 0.0
          Sensors Vin Z-Probe
          24.5 V 1000
          Machine Control
          Print Status
          G-Code Console
          G-Code Files
          Macros
          Filaments
          Settings
          8:45:53 PM
          Connection established!
          8:45:40 PM
          Disconnected.
          8:43:22 PM
          M32 0:/gcodes/ethernet setup.txt
          File 0:/gcodes/ethernet setup.txt selected for printing
          MAC: be:ef:de:ad:fe:ed
          RepRap name: kathryn printer
          8:18:04 PM
          M122
          Used output buffers: 2 of 32 (8 max)
          Static ram used: 24996
          Dynamic ram used: 89564
          Recycled dynamic ram: 128
          Stack ram used: 1104 current, 3784 maximum
          Never used ram: 12600
          Last reset 00:01:08 ago, cause: software
          Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
          Spinning module during software reset: GCodes, available RAM 12528 bytes (slot 0)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 35.3, current 38.3, max 39.6
          Supply voltage: min 0.6, current 24.5, max 25.0, under voltage events: 0, over voltage events: 0
          Driver 0: standstill
          Driver 1: standstill
          Driver 2: standstill
          Driver 3: standstill
          Driver 4: standstill
          Date/time: 2017-11-21 20:17:59
          Slowest main loop (seconds): 0.607820; fastest: 0.000042
          MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Probe change coordinates:
          Bed heater = 0, chamber heater = -1
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          • elmoretundefined
            elmoret
            For starters, check for typos. Right off the bat I see a few typos in your config.g file:
            on M563 you have "PO" instead of "P0"
            on m584 the M should be capitalized
            The M501 at the end of config.g is calling for the loading of config-override.g, so you'll want to post that here too.
            It also wouldn't hurt to post a diagram of how you've connected the stepper drivers to the board, and also what make/model the stepper drivers are (so active high/low can be set properly, as well as step width).
              sjason1377 Banned
              kl-5056 from automation technologies. auto active high low whatever they set them selves as far as pulse goes. dir would still work 1 direction. pulse width 1.2us step+ to step+ step- to step- and so on. fully matched polarities on all connections. it worked before using the test ports the latest diagram say not to use. I removed those singal leads when I saw the update. this was a running machine. I only move to the expansion header as per instruction. now I have no machine.
              • elmoretundefined
                elmoret
                Yes, when you were using test points, the machine needed to be configured to use drives 0-4. Now you're using drives 5-11, and need to set things up accordingly. This is done in the M569 commands, which are still set up for drives 0-4 it seems.
                I've never heard of an "auto active high low", I don't know how that would be possible - how would the stepper driver guess what a signal is supposed to mean? The product manual for the KL-5056 states that high enables the driver, low disables the driver. But in your M569 commands you have a mix of some active high, some active low.
                Have you corrected the aforementioned typos? Where do things stand now? What about the config-override.g? A wiring diagram would still be helpful, both for now and for any future troubleshooting/questions.
                I understand you're frustrated, but please see that you're trying to do something uncommon and unconventional, and therefore difficult. This is further complicated by only providing partial information. There are a lot of folks trying to help, it wouldn't hurt to show them some appreciation, too.
                  sjason1377 Banned
                  M557 R78
                  ; tools
                  M563 P0 D6:8:9 H1 F2
                  G10 P0 S0 R0 X0 Y0
                  M569 P10 S1 R1 T2 ; Drive 10 goes forwards
                  M569 P11 S1 R1 T2 ; Drive 11 goes forwards
                  M569 P5 S1 R1 T2 ; Drive 5 goes forwards
                  M569 P6 S1 R1 T2 ; Drive 6 goes forwards
                  M569 P8 S1 R1 T2 ; Drive 8 goes forwards
                  M569 P9 S1 R1 T2 ; Drive 9 goes forwards
                  M584 X10 Y11 Z5 E6:8:9
                  M350 X16 Y16 Z16 E16:16:16 I0 ; Configure microstepping without interpolation
                  M92 X100 Y100 Z3200 E80:80:80 ; Set steps per mm
                  M307 H7 A1 C1 D1
                  • elmoretundefined
                    elmoret
                    Yes, it is possible to run 12 steppers from a Duet.
                    If you don't have a config-override.g, then you shouldn't be calling M501 (at the end of config.g).
                    I'm asking for a wiring diagram because it is necessary to know how things are connected in order to set up config.g. I don't have any way of knowing how to set up the active high/low parameter without seeing how you've connected things, for example. If the stepper enable is not configured correctly, no motion will result.
                    It looks like you still haven't fixed the typos I mentioned in the first post, nor the M569 commands. It looks like you changed the comments on the M569 commands, but not the commands themselves. The comments are ignored by firmware, they are just there as human-readable notes.
                    I don't know how else to try to help when you're not following the suggested fixes. I do wish you the best with your build.
                      sjason1377 Banned
                      i didn't run the config program the admin did
                        sjason1377 Banned
                        that was generated for me and I on changed axis requirements
                          sjason1377 Banned
                          pasta function pasted the wrong copy sorry
                          • elmoretundefined
                            elmoret
                            I took your updated config file posted above (looks like you deleted your post and posted a new version while I was posting), and can verify that the step/direction signals are being generated, see attached.
                            I verified all of the axes, even though it meant taking the time to update my dev board's firmware.
                              sjason1377 Banned
                              Ok thanks for that. I have movement on x and z only. they are on drives of different controller ends. 1 on lcd and the other expansion. z only move during homing which fails. I can jog x only. y and all three extruders are dead sticks still. now everytime I make a change to the config via web I can't reconnect. it's the same ethernet connection. I removed the enable leads to auto enable drives. that worked for enable and I have some movement. But the connection error say can't connect to firmware. I can access the web control be address but not reconnect. I have to use usb and repeteir host to send M552 S1 everytime the un plug usb, because the ethernet wont connect with usb even plug in. I am power my desktop and the printer from the same power supply so gnd is common.
