    First time autotuning… Questions
    2.7k
      The default bed temperature limit is 110C. You can increase it using the M143 command.
      The warning message is telling you that if there was a fault and the heater got left on at full power, it would get very hot. You might want to consider adding a thermal cutout, and/or turn the power supply voltage down a little (and then return retune both heaters).
      • vbtalentundefined
        vbtalent
        @dc42:
        …You might want to consider adding a thermal cutout, and/or turn the power supply voltage down a little (and then return both heaters).
        Thanks Dave, are you saying that you think the bed heater is defective?
        Could you elaborate a little more…
        VB,
          Sorry, I made a typo and it got auto corrected to 'return' instead of 'retune'.
          • vbtalentundefined
            vbtalent
            No worries… thanks for clarifying.
