    Beta 3 loosing connection.
    Beta Firmware
    • Sn1gerundefined
      Sn1ger
      hi
      one of the printers, in the house is running with beta 3
      but sometimes im loosing connection to the web interface. Wifi led is on. and i can find the server ip on the router, The issue is gone after restarting the board, but sometimes it shows up again..
      i did try to ping the server and no error even without connection to web interface.
      i notice when one computer is on the webinterface. and i go in from the mobile, Then the web interface refreshes on the computer.
      some info
      2.4 ghz wifi
      Channel 1.
      WPA2
      Duet2wifi:
      running with beta 3
      DuetWiFiModule_32S3.bin
      i can´t send the M122 log yet, as the printer is running, and i cant connect to it yet. 😛
      Best regards from me
        jay_s_uk @Sn1ger
        @Sn1ger you won't be using duetwifiserver_32s3.bin unless you've radically hardware modified your duet 2 so I suggest you haven't updated to the latest wifi server code.
        Upload the none 32s3 one
