    External Driver Issues
    232
    • apiazza2010undefined
      apiazza2010
      First of all, super helpful forum, found many answers, thank you everyone!
      I currently have a 6XD. I have a cartesian printer with dual Y and single X intergrated motor/driver connected to the driver output on 5v and ground trigger.
      I am having issues with Z and extruder, for these I'm using external driver ST-4045-A1
      What am I doing wrong? I tried messing with the M569 but no difference.
      The motors aren't enabled (I can spin them), yet the LED for pulse turns on in the driver.
      Thank you,
      Andrew
      apiazza2010undefined 1 Reply Last reply Reply Quote 1
        apiazza2010 @apiazza2010
        @apiazza2010
        I have connected them in a variety of ways, but I get the same issue every time. The LED light for pulse turns on when I send a movement, but the motor doesn't turn. I checked phase and double checked the driver work with a different board.
        They are connected using the diagram shown in the guide
        apiazza2010undefined 1 Reply Last reply Reply Quote 0
          @apiazza2010
          Update, got the M5045 Driver to work, but the enable pin is inversed, as in it's enabled low and disabled high.
          I tried adding R1 to the M569 line for the Z axis, but it doesn't work.
            dc42 administrators @apiazza2010
            @apiazza2010 the 6XD board has a jumper for selecting the enable polarity.
              apiazza2010 @dc42
              @dc42 Hello,
              Thank you very much for the help.
              With the polarity switch, I assume it changes the behaviour for all of the drivers output right?
              R1 or so in the firmware does nothing on 6XD Boards right?
              Thanks
                @apiazza2010 the jumper changes the Enable polarity for all drivers.
                I thought the R1/R0 option did work on the 6XD but I'm not in a position to verify that right now. The jumper had the advantage that you can ensure that the motors are disabled at power up.
                  apiazza2010 @dc42
                  @dc42 Hello,
                  I'm now running them using a relay to invert the logic of just the Z and Extruder driver, while dual Y and X are on normal logic.
                  Do you know if R0/R1 does work on 6XD ?
                  Thank you very much
                    @apiazza2010 on the 6XD the jumper sets the default value (R1 or R0) for all drivers at power up. You can use M569 P# R1 or R0 (where # is the driver number) to change the enable value for an individual driver. Use M569 P# to display the existing value.
