    Intermittent issue with homing... Duet3 5+ wifi
    Firmware installation
    1
    • gumbyundefined
      gumby
      (I am going to post this in three chunks, because it got flagged as spam when I did long format)
      I am making progress on my Predator updates. I have been having one odd intermittent issue with homing.
      I have been restarting like a madman, as I tweak settings, etc. and sometimes I get the
      G28 Error: G0/G1: target position not reachable from current position.
      It's only once in a while and I have tried running line by line. It usually gets stuck on the last line of the Macro.
      G1 X0 Y0 F6000 ; move X+Y to the center
      gumbyundefined 1 Reply Last reply Reply Quote 0
      • gumbyundefined
        gumby @gumby
        @gumby
        This is usually after the G90 absolute command and I notice it seems to be when there are numbers in the Z axis that are high relative to my printer... Such as Z800 ish. (My printer only should go into the low 400s).
        I'm assuming there is a place where the maximum allowed Z travel is causing this, but I cannot find where that would be in the firmware. I see a minimum line as:
        M208 Z-9999 S1 ; set minimum Z
        But cannot find a maximum declared anywhere.
        Is this something common? I have tried all the suggestions I could find, like the second to last command dropping 15mm instead of 5, but that didn't seem to help
        Thanks for any wisdom on this issue.
        Gumby
        I am using Duet3 5+ Wifi and a smart effector, with the latest stable release.
        • gumbyundefined
          gumby @gumby
          @gumby ```
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Apr 20 2023 10:24:19 GMT-0400 (Eastern Daylight Time)
          M550 P"Predator" ; set printer name
          M665 R226.9 L450.7 B185 H410.4 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S1 ; enable Telnet
          M569 P0.0 S0 ; physical drive 0.0 goes backwards
          M569 P0.1 S0 ; physical drive 0.1 goes backwards
          M569 P0.2 S0 ; physical drive 0.2 goes backwards
          M569 P0.3 S1 ; physical drive 0.3 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
          M92 X160.00 Y160.00 Z160.00 E663.00 ; set steps per mm
          M566 X3000.00 Y3000.00 Z3000.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X8000.00 Y8000.00 Z8000.00 E4000.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
          M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
          M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
          M558 P5 R0.4 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
          M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
          G31 P500 X0 Y0 Z-0.31 ; set Z probe trigger value, offset and trigger height
          M557 R185 S40 ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M307 H0 R0.399 K0.380:0.000 D1.32 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1
          M143 H1 S300 ; set temperature limit for heater 1 to 300C
          M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
          M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
          • gumbyundefined
            gumby @gumby
            @gumby ```
            ; homedelta.g
            G91 ; relative positioning
            ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
            G1 H1 X800 Y800 Z800 F3600 ; move all towers to the high end stopping at the endstops (first pass)
            G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
            ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
            G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
            G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
            G90 ; absolute positioning
            G1 X0 Y0 F6000 ; move X+Y to the centre
