    Anycubic Kossel Linear Plus power supply to duet2 Maestro
    • Phillg2kundefined
      Phillg2k
      Hi, I have the above Delta printer with a Trigorilla1.1 main board which is supplied with a 11A & 5A power cables from what I assume is a ATX type power supply shipped with the Delta.
      I wanted to switch over to a Duet2 Maestro Ethernet board as its 32bit & quieter in operation. I've fitted this new board to my printer & started wiring it, but do not have a 5A terminal block on the Maestro to wire to & don't understand were they're supposed to go.
      When I power up the board, nothing happens presumably because there's no power being drawn from the 5A side of the power supply. Can anyone help please. I'm new to 3D printers.
      Regards
        dc42 administrators @Phillg2k
        @Phillg2k if it is an ATX power supply then you will need to put a dummy load on the 5V output to make the power supply work. You may also need a dummy load on the 3.3V output.
