    IDEX : U axis not moving after home
    • ronnien59undefined
      ronnien59
      I have gotten all the way to this. When i home x axis i can still move axis however after homing the U axis it will not move. I have posted Movement section:
      ; Movement section
      M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P4 S1 ; Drive 4 goes forwards
      M569 P5 S1 ; Drive 5 goes forwards
      M584 X0 Y1 Z2 U3 E4:5 ; Create U axis for second X carriage before we try to configure it
      M574 X1 Y1 Z0 U2 S1 ; Set endstop configuration (X and Y endstops at low end, U endstop at high end, active high, no Z endstop)
      M906 X800 Y800 U800 Z800 E1000 ; Set motor currents (mA)
      M201 X800 Y800 U800 Z15 E1000 ; Accelerations (mm/s^2)
      M203 X15000 Y15000 U15000 Z100 E3600 ; Maximum speeds (mm/min)
      M566 X600 Y600 U600 Z30 E20 ; Maximum jerk speeds mm/minute
      M208 X200 Y200 U250 Z200 ; Set axis maxima (adjust to suit your machine)
      M208 X-50 Y0 U0 Z-0.2 S1 ; Set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
      M92 X80 Y80 U80 Z2560 ; Set axis steps/mm
      M92 E420:420 ; Set extruder steps per mm
      G21 ; Work in millimetres
      Is there something i am missing?
        Please post your homeu.g file.
          ronnien59
          Here is my homeu.g file
          G91
          G1 Z4 F200
          G1 U240 F3000 S1
          G1 U-4 F600 S2
          G1 U10 S1
          G1 Z-4 F200
          G90
            ronnien59
            Solved!! it is working Thanks
