    Idex second Z probe on the U axis
    IR Height Sensor
    • Proschi78
      Proschi78 last edited by Proschi78
      I have an IR Probe on my X axis and a BL Touch on the U axis. When I create a height map with the u axis, Y and U are swapped. On the height map, U then runs in the Y direction and Y in the X direction. why is that?
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d https://youtube.com/@proschi3d
        dc42 administrators @Proschi78 last edited by
        @Proschi78 are the axes just shown incorrectly in the height map viewer, and the actual compensation applied is correct?
        Please show the GCode commands that you are using to generate the height map.
        Proschi78 1 Reply Last reply Reply Quote 0
        • Proschi78
          Proschi78 @dc42 last edited by Proschi78
          @dc42 said in Idex second Z probe on the U axis:
          I only use G29 K1
          i have a Macro with the M557 U66:300 Y2:230
          I start first, and then I give the G29 K1 command.
          I haven't started printing yet to see if it's just rotated in the map.
          I think it's better to have both on the same axis, unfortunately I don't have space on the x-axis for the additional BL touch.
          Since I like to print on structured Pei, I need the Bl Touch.
