    DUET 3D MAINBOARD 6HC WIRING
    • SANJRundefined
      SANJR
      Re: DUET 3D MAINBOARD 6HC WIRING
      Hi
      This question is related to one of the old discussion, 2 DC Brushless DC motors would be connected to OUT1 and OUT3.
      To vary the speed of the motor PWM function is planned to use M950 and M42 Commands.
      Can this motor be used or only a brushed DC motor is to be used?
      Stephen6309undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @SANJR
        @SANJR Yes they can. You'll have test them to see what the minimum speed you can run them at. For some you have run them at max speed for a second before you can run them at a low speed.
        SANJRundefined 1 Reply Last reply Reply Quote 0
        • SANJRundefined
          SANJR @Stephen6309
          @Stephen6309 Thanks for the Update
            dc42 administrators @SANJR
            @SANJR it would be better to use a BLDC motor with an electronic speed controller (ESC) and then control the ESC from a PWM-capable IO_OUT port on the Duet.
            • SANJRundefined
              SANJR @dc42
              @dc42 Thanks for the Update
