    I don't get it...
    • nikschaundefined
      nikscha
      I'm trying to tune input shaping on my delta. Could someone help me interpret these results:
      Here I'm taking measurements WITH the extruder installed:
      And here WITHOUT the extruder (lower inertial mass):
      I understand that with the lower mass the resonance frequencies are increasing, but why does the amplitude increase as well? Shouldn't there be less energy in the system?
      Am I better of with an extruder? I.e. will I experience less ringing with an extruder? Will the high-frequency ringing be less visible than the low frequency ringing?
      Stay in school
        dc42 administrators @nikscha
        @nikscha the accelerometer measures acceleration, not the amplitude of ringing. Ringing at higher frequencies has higher acceleration, so the accelerometer will respond to it more.
        There may be a case for us to scale the amplitude in inverse proportion to frequency when displaying those plots.
        nikschaundefined 1 Reply Last reply Reply Quote 0
        • nikschaundefined
          nikscha @dc42
          @dc42 I see, that clears things up. Thank you.
          I have another question:
          What is the XY option in the 'record motion profile' dialog?
          I tried it with the same values I used for just X/Y and had a crash (I have a delta).
          And another question:
          Does the orientation of the accelerometer matter on the delta? (As long as Z points upwards) X/Y will always have some "random" relationship.
          Stay in school
            @nikscha said in I don't get it...:
            That should perform an X motion and a Y motion, and record both of them. Please provide more details of the crash, i.e. what the motion profile settings were and what happened.
            No, it shouldn't matter.
