    install the auto z-offset again
    Using Duet Controllers
    • axiomundefined
      axiom
      I would like to try to install the auto z-offset again. I have already connected the switch and it reacts as it should on the board (green light).
      For the filament sensor, I successfully wrote the following into the config.g:
      M591 D0 P3 C"e0_stop" S1 ; filament monitor connected to E0_stop
      But which M-command do I have to write in for the auto z-stop?
      Then I have to create a macro.
      How do I call up the event and what do I have to write into the macro?...
      The previous descriptions never mentioned the basics (e.g. config.g).
      Now I want the macro to say that the print head moves onto the switch until it is triggered?
      The switch is about 15mm higher than the bed.
      Then should he set Z to zero in G92 Z0 ?
      Then he should use the Z probe to read out G1 x.. y.. and Z G92 z0 via the drive switch. He should then pass this value to the config.g.
      How should I do that?
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @axiom
        @axiom
        Most of what you want to do is handled by homez.g and homeall.g
        The rest is covered in these documents
        https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting
        After calibration, you can edit your G31 Z offset in config.g
        My suggestion would be to use the RRF configuration tool to create a set of macros suited to your machine.
        https://configtool.reprapfirmware.org/Start
        You can then use thee as the basis for any modifications required.
        • Proschi3Dundefined
          Proschi3D
          G31 Z0						; set Z-offset to Z=0
          echo >"0:/sys/config_probe.g" "G31 Z0"
          M291 S3 R"Heating up nozzle" P"Wait for the nozzle to reach printing temperatures"
          M568 P0 S210				; set tool 0 (primary hotend) temperature to 230c
          T0							; select tool 0 (primary hotend)
          M116 P0 H5					; wait for temperature to reach within 5c of set temperature
          M83							; relative extruder moves
          G1 E-5 F300 				; retract 5mm of filament
          G4 P0						; wait for movements to have stopped
          M300 S666 P666 				; beep
          M291 S3 R"Automatic Z Offset Calibration" P"Press OK to continue, or CANCEL to abort"
          M291 S3 R"Homing axes" P"Remove the puck. The printer will home the X, Y, and Z axises without the puck"
          M98 P"config_probe.g"												; Load BLTouch probe settings
          M280 P0 S60 I1														; clear any probe errors
          G29 S2                      										; cancel mesh bed compensation
          G91                    												; relative positioning
          M913 X50 															; X axis 50% power
          G1 H2 Z5 F200          												; lift Z relative to current position
          G1 H1 X{(move.axes[0].max+5)*-1} Y{move.axes[1].max+5} F6000  		; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y-5 F600      												; go back a few mm
          G1 H1 X{(move.axes[0].max+5)*-1} Y{move.axes[1].max+5} F600  		; move slowly to X and Y axis endstops once more (second pass)
          M913 X100 															; X axis 100% power
          G90                    												; absolute positioning
          G1 X{move.axes[0].min+5} Y{move.axes[1].min+5} F6000 				; move to front left
          G1 F600																; reduce speed
          G30                    												; home Z by probing the bed
          M564 H1 S0             		; Negative movements are allowed
          G1 Z27						; raise Z to 27mm
          M291 S3 R"Clean the nozzle" P"The nozzle has been pre-heated. Clean it from any plastic debris"
          G1 X100 Y200 F6000			; go to X100, Y200
          M291 S3 P"Place the offset tool below the nozzle and press OK to perform the macro, or CANCEL to abort"
          G4 P200 					; wait 200ms
          G91							; relative moves
          G1 H1 Z-12 F50				; move 12mm down, stop when hitting the offset tool (but don't risk crashing the bed)
          G92 Z0 						; set current position as Z=0
          G1 Z7 F200					; move up 7mm
          G1 X{sensors.probes[0].offsets[0] * -1} Y{sensors.probes[0].offsets[1] * -1} F1500 ; move nozzle so that BLTouch is in it's position
          G90							; absolute moves
          G30 S-3 					; probes Z and adjusts the probe trigger height to match the actual stop height.
          G91							; relative movement
          M568 P0 S0					; set tool 0 temperatures to 0
          var Z_auto_offset = {sensors.probes[0].triggerHeight} ; math to calculate the BLTouch offset
          	if var.Z_auto_offset < 0.01
          		M291 S2 R"The nozzle has not touched the puck." P"Please check the guide for troubleshooting"
          		echo "The nozzle has not touched the puck. Please check the guide for troubleshooting"
          		echo >"0:/sys/config_probe.g" "G31 Z-3"
          	elif var.Z_auto_offset >= 0.01 & var.Z_auto_offset < 3.5
          		echo >"0:/sys/config_probe.g" "G31 Z"^{var.Z_auto_offset}
          		M291 S2 R"Z-offset has been stored" P"the Z-offset has been stored in the config_probe.g file. Verify the value stored with the value displayed in the console"
          		echo "the Z-offset has been stored in the config_probe.g file. The Z-offset is", var.Z_auto_offset, "mm. Remove the offset tool and place it back in the box"
          	elif var.Z_auto_offset >= 3.5
          		M291 S2 R"Z-Offset is too high" P"Please verify the probe height using the probe-calibration"
          		echo "Z-Offset is too high. Please verify the probe height using the probe-calibration"
          M564 S1 H1      			; Negative movements are forbidden
          G1 Z5						; lift nozzle up 5mm
          T-1							; deselect all tools
          M18							; release steppers
          Love my Duet 3 Mini.
          https://www.instagram.com/proschi3d
          https://youtube.com/@proschi3d
          https://www.proschi3d.de
          axiomundefined 1 Reply Last reply Reply Quote 0
          • axiomundefined
            axiom @Proschi3D
            @Proschi78 Thanks very much!
            but I still don't understand what I have to write in the Config.g?
            "M574 D0 P1 C"e0-stop" S2" ???????I'm missing the basic information
            Proschi3Dundefined 1 Reply Last reply Reply Quote 0
              Proschi3D @axiom
              @axiom
              I'm currently swamped with a lot of things.
              Once I find some time, I will help you and answer your questions.
              Best regards,
              Jan
              • axiomundefined
                axiom @Proschi3D
                @Proschi78 That would be very nice and helpful...I'm completely stuck...I've made some progress...but still a long way from the goal
                • metabo7000undefined
                  metabo7000
                  How can you do such an automatic measurement with a macro that older filmware could also interpret, e.g. 2.02(RTOS) (2018-12-24b1)!?
                  video1
                  https://www.youtube.com/watch?app=desktop&v=gvwfQ_r7xoU
                  video2
                  https://www.youtube.com/watch?app=desktop&v=00g7d2wuFAI
