Sammy 21C invalid firmware
Hello all
I picked up a couple of Sammy21C to do a little experimenting and when I power them (viaUSB) I get the following:
Invalid firmware
M115
Block receive timeout
Invalid firmware
Invalid firmware
Invalid firmware
Block receive timeoutCan any one explain whats going on? It is meant to have a Duet3D boot loader - Do I need to connect it to Main duet board (mini5+) to load something or can I load the firmware from the USB?
I just wanted to make sure the board is working - is there any M commands that it will understand as a boat loader ? Is there a way to load the firmware from USB?Thanks for your help
@Behrouz-AKT those messages mean that the bootloader is installed but no main firmware. It is trying to download firmware over CAN from a Duet 3 main board but not getting a response.
If you want to use our sample SammyC21 firmware binary, you will need to connect it to your Mini5+ and upload that binary to the Mini5+.
understood, thanks
