Issue with a M571 "Set output on extrude" Command
Hello everyone.
For a student project I'am trying to add a non extrusion tool to a multitool 3D-printer.
To be pricise the new tool is a dispenser, to apply soldering paste.
RepRap 3.3 (I know, out of date) on Duex5 v0.11I stumbled apon M571 and tryed to get it to work via an unused FAN output and GPIO.
The lines are:M571 P"duex.fan8" S1.0
M571 P"duex.gp1" S1.0None of these commands work how they should. Nothing happens and no error massage. However GPIO will switch on the signal, as soon as it hits the M571 line.
What am I missing? -
The notes on those pins says they can't control a laser. Which may mean won't work with M571.
https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
Can you test with a heater/pwm pin?
