    PanelDue 7i firmware update: What should I expect?
    PanelDue
    • paralepsisundefined
      paralepsis
      Hi, I've got a 7i that I received a while back as part of a Railcore build. It's on firmware 1.24 according to the settings page. The panel works fine, I just want to update firmware for all the good reasons one does that sort of thing from time to time :).
      My Duet3 controller is on 3.4.5, and I'd like to update the panel to the 3.4.1 firmware. I've tried uploading the firmware into the firmware directory and selecting Install Firmware File per instructions (https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue).
      This errors out early with "Error: Failed to communicate with PanelDue bootloader (no START signal received). Please try again or press the Erase and Reset switches on PanelDue."
      Two questions:
      (1) Is this expected behavior with this combination of display, controller, and firmware(s)?
      (2) Is the Erase+Reset going to work, or do I just need to break out the USB cable (and crack open the case holding this panel)?
      Thanks!
      Rob
      Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @paralepsis
        @paralepsis said in PanelDue 7i firmware update: What should I expect?:
        Two questions:
        Yes, try it. If it can't flash it from there, you would need to use the USB cable and bossa to flash it at least once to get it to a modern version which works with flash from DWC.
          dc42 administrators @paralepsis
          @paralepsis yes you need to use the PanelDue Erase and Reset buttons to upgrade PanelDueFirmware from version 1.x.
          paralepsisundefined 1 Reply Last reply Reply Quote 0
            paralepsis @dc42
            @dc42 Pressing two buttons worked great, was able to flash from web UI. Thanks all!
            • StevenLundefined
              StevenL
              I've got TWO of the same 7i panel. One for my Railcore ZL and another the ZLT.
              Can you list the steps to do this upgrade?
                Phaedrux Moderator @StevenL
                @StevenL said in PanelDue 7i firmware update: What should I expect?:
                These steps? https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
