    Error: G29: No valid grid defined for bed probing
    • DatTurtleundefined
      DatTurtle
      I recently got a BLTouch set up and have been trying to probe my bed but keep getting the same error with g29/g29 s0. Probe deploys/retracts fine and g30 works for single probes but I'm missing something with my grid. Thanks for the help!
      Config.g
      ; Configuration file for Duet Maestro (firmware version 3)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Zaphod"                              ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M551                              ; set password
      M552 S1 P0.0.0.0                         ; enable network and set IP address
      M553 P255.255.255.0                            ; set netmask
      M554 P10.0.0.1                                 ; set gateway
      M586 P0 H1                                     ; enable HTTP
      M586 P1 H1                                     ; enable FTP
      M586 P2 H0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S0                                     ; physical drive 1 goes backwards
      M569 P2 S1                                     ; physical drive 2 goes backwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M569 P4 S1
      M584 X0 Y1 Z2:4 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I0                      ; configure microstepping without interpolation
      M92 X70 Y64 Z850 E200             ; set steps per mm
      M566 X1000.00 Y900.00 Z600.00 E240.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X3000.00 3000.00 Z700.00 E3000.00       ; set maximum speeds (mm/min)
      M201 X1200.00 Y1200.00 Z300.00 E240.00            ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E1000 I50               ; set motor currents (mA) and motor idle factor in per cent
      M84 S60                                        ; Set idle timeout
      M208 X0 Y0 Z0 H1                               ; set axis minima
      M208 X380 Y400 Z480 H0                         ; set axis maxima
      M574 X1 P"xstop" S1                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"                           ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 P"zstop" S1                             ; configure unsupported switch-type endstop for low end on Z via pin null
      ; Z Probing
      M950 S0 C"zprobe.mod"                          ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z1.2                            ; set Z probe trigger value, offset and trigger height
      M557 X15:390 Y15:390 S15 ; define mesh grid                      ; define mesh grid
      M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
      M671 X20:360 Y0:460 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X0:400 Y0:400
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3988 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4006  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S260                                   ; set temperature limit for heater 1 to 260C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0.8                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q250                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1.0 H1 T150
      M950 F2 C"fan2" Q500
      M106 P2 S0.8  ; set fan 1 value. Thermostatic control is turned on
                                    ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M929 P"eventlog.txt" S1
      ; Filament sensor
      M591 D0 P2 C"e0stop" S0
      M501                                           ; load saved parameters from non-volatile memory
      T0                                             ; select first tool
      Bed.g
      ; bed.g
      G28 ; home
      M401 ; deploy Z probe (omit if using bltouch)
      G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M402 ; retract probe (omit if using bltouch); generated by RepRapFirmware Configuration Tool v3.3.12 on Wed Aug 03 2022 13:48:07 GMT-0400 (Eastern Daylight Time)
      G29  ; probe the bed and enable compensation
        Your M557 grid command says the range goes to X390, but your M208 says the X axis is only 380mm long.
        You're also missing the XY offset of the probe in your G31 command.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_mesh_bed
