Question on Refresh Jobs
When I refresh jobs every job in the list is reloaded and it takes longer than it should. Is there a way to refrsh only new or updated jobs? Thanks
DWC version?
@Phaedrux 3.4.5
Standalone or SBC? What Duet? How fast is the SD card? How long is it taking? Are the job gcode files very large? Do you have thumbnails in the jobs as well?
@Phaedrux said in Question on Refresh Jobs:
Stand Alone
Voron 2.4R2 Duet 3Mini +5I think it is a class 10 Samsung 64 or 32G (Not easy to get to but it is a newer card)
Duet 2 WiFi 8GB EDGE SamsungBoth Machines have the same issue
G-Code files are average size 2-10MB in the que now
Yes I have thumbnails (also: how do i turn them off)
Hope this helps
Thanks
@JADoglio said in Question on Refresh Jobs:
How long is it actually taking?
Using this load it takes about 25 seconds. The total time is not really the question. The question is, why does it reload all files in the que when I add one new one. I assume that if I only load the new one, and not 5, it will be faster. Thanks
@chrishamm Is this the expected behaviour?
@Phaedrux Yes, it is. Pressing "Refresh" invalidates the file cache and buffered thumbnails, so it may take a while before the full job list is loaded again. I think DWC should automatically update active file lists when something on the SD card changes and I've logged an issue for this on GH: https://github.com/Duet3D/DuetWebControl/issues/476
@chrishamm Thanks for the update.
