Hot swap PanelDue?
  • Is it OK to disconnect PanelDue from printer while it's powered on?
    I'm using PanelDue mostly for calibration and occasionally for a starting prints. The question is whether I can start a print with PanelDue, disconnect it from the printer and start using the screen with other printer? I know I can do this, but how big is the probability that I let the magic smoke out while doing so?
  • I've done it without issues.
    It's not recommended, as with any other electronic equipment that isn't specifically designed to be connected or disconnected while powered.
