Object model changes in RRF 3.5.0-beta4
Just read through the changelog, and i see that some object model fields have been removed (which i currently use)..
So just to verify if i understood the changes i need to do correct or not, could someone (brigther than me) have a look at these before i deploy them?
move.compensation.probeGrid.mins[0]
= ok?
move.compensation.probeGrid.maxs[0]
= ok?
move.compensation.probeGrid.mins[1]
= ok?
move.compensation.probeGrid.maxs[1]
= ok?move.compensation.probeGrid.spacings[0]
= ok?
move.compensation.probeGrid.spacings[1]
= ok?sensors.probes[0].speeds[0]
= ok?
sensors.probes[0].speeds[1]
= ok? -
@Exerqtor those look valid to me; but you haven't told us what you were using before, so I can't say whether those are the correct replacements.
Ok goodie!Yeah I know, I felt like a had a good enough grasp of what fields replaced the ones i allready had. Just wanted to make sure i had "structured" them right.
They've been deployed, tested and work like intended now
undefined Exerqtor marked this topic as a question
undefined Exerqtor has marked this topic as solved
