Motor Current
  • Hi David Dc42
    Why on DWC the value Motor Current is 0 mA …is bug ?
    My Config on 1.9.3 /1.20 beta 10 Duet Ethernet
    M906 X1200 Y1200 Z1200 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
    Thanks
    It could mean that config.g from your SD card is not being read at startup, or that something is causing processing of config.g to end prematurely.
  • It does the same thing on my duet with beta 8. Everything works fine. Just noticed this last night.
  • On DWC is 0mA….but on line command M906 is ok ...
    why ?
    Thanks
  • Mine is the same - looks like a glitch in the machine properties tab of DWC. Never looked at it before so it might have been there for ever. M906 with no parameters is the reliable indicator - ignore the values shown in the machine properties tab of DWC. I guess this is one for Chris Ham, not David.
  • @deckingman:
    Ok Thanks for the moment ….But on 1.9 FW is perfect on DWC...i reed 1200 mA
  • Just for comparison, it seems to be a recent bug. It's fine on mine.
    Firmware Name: RepRapFirmware for Duet WiFi
    Firmware Electronics: Duet WiFi 1.0
    Firmware Version: 1.20beta1 (2017-10-02)
    WiFi Server Version: 1.20alpha1
    Web Interface Version: 1.19.3
