    Allow Interruption of Heater Command
    Firmware wishlist
    • CCS86undefined
      CCS86
      It would be very nice if the "Pause Print" command were able to interrupt an M109.
      I find on a semi regular basis that at the start of a print, I may want to change something or cancel the print. But if an M109 has already been issued, DWC is unable to interrupt this command and it must complete before allowing any intervention. I know that I could E-stop it, but allowing a graceful pause/cancel in these cases would be nice.
        dc42 administrators @CCS86
        @CCS86 I believe this is working in firmware 3.5.0-beta.4. Please test and confirm or not. See https://github.com/Duet3D/RepRapFirmware/issues/763.
        T3P3 created this issue in Duet3D/RepRapFirmware
        closed Can't pause while bed or tool is heating #763
        CCS86undefined 1 Reply Last reply Reply Quote 0
        • CCS86undefined
          CCS86 @dc42
          @dc42 said in Allow Interruption of Heater Command:
          Perfect, it is working!
          Pause button "completes", which allows it to transform into the cancel button. The heater continues heating after pausing. The heater turns off if you then cancel.
          (Sorry for duplicating the report)
          • dc42undefined dc42 marked this topic as a question
