    Strange type conversion error RRF3.5.0b4
    Beta Firmware
    • OwenDundefined
      OwenD
      I'm not sure if this is specific to RRF3.5.0b4 as I've only just noticed it.
      Duet 2 WiFi 2WiFi 3.5.0-beta.4
      Duet WiFi Server n/a 2.1beta3
      Duet Web Control DWC 3.5.0-beta.4
      When I was having problems with WiFi related SPI errors on my Duet2 WiFi (now fixed), I decided to add a section of code to daemon.g to monitor the status of the WiFi module, restart it if necessary and log the disconnect.
      I had thought that it was all working as planned, but as my printer is in the shed and I'm rarely in front of it when I do a restart, I noticed an error appear on the PanelDue that never shows up in DWC, because the WiFi has yet to connect.
      The error is as follows
      Line 157 is in daemon.g and is the first line after the "else"
      global NetworkRestartTime = (state.time + 60)
      	; check if wifi is connected
      	if (network.interfaces[0].actualIP="0.0.0.0") || (network.interfaces[0].actualIP=null)  || (network.interfaces[0].state!="active")
      		if exists(global.NetworkRestartTime)
      			if global.NetworkRestartTime > state.time
      				if fileexists("0:/sys/print_log.txt")
      					echo >>"0:/sys/print_log.txt" "WiFi disconnected:  Restart attempted at : " ^ state.time
      				M929 P"0:/sys/print_log.txt" S3
      				M122
      				M552 S-1 ; disable wifi
      				G4 S2
      				M552 S1 ; enable wifi
      				M929 S0; stop logging
      				set global.NetworkRestartTime = (state.time + 60)
      		else
      				echo >>"0:/sys/print_log.txt" "WiFi disconnected:  WiFi module restart schedued for " ^ global.NetworkRestartTime
      The strange part is that if I send that line on the console, it works fine.
      And also if I delay running the code until after the wifi connects, it also works fine.
      So this works with no errors
      		if state.upTime < 60
      			break
      				M122
      				G4 S2
      		else
        dc42 administrators @OwenD
        @OwenD I think the issue is that RRF doesn't know the time until DWC connects and passes the time to the Duet. I suggest you add a check that state.time isn't null before using it.
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @dc42
          @dc42 said in Strange type conversion error RRF3.5.0b4:
          Nailed it!
          I'll use state.upTime instead.
          • OwenDundefined OwenD marked this topic as a question
          • OwenDundefined OwenD has marked this topic as solved
