    PanelDue Cable Length
    • Adamfilipundefined
      Adamfilip
      Curious what the max recommended cable length is between the Duet Wifi and PanelDue
      • iDeveloundefined
        iDevelo
        Mines about 3m long and seems fine.
          Several metres is no problem, but I recommend that you limit the resistance per conductor to 0.1 ohms. For really long cable lengths you can reduce the baud rate. However, if you are using the ribbon cable to connect the SD card socket on the version 2 PanelDue then the maximum recommended ribbon cable length is 0.5m and I have only tested up to 0.8m.
