    Connecting External loads
    • Thierry14undefined
      Thierry14
      Hi All,
      Connecting high power led with fixed current
      What is the best way to connect and control it with duet?
      It would be great if you can suggest if I should power externally or which pins should I use.
      Thanks a lot
        dc42 administrators @Thierry14
        @Thierry14 those LED mustn't be connected directly to outputs of the Duet because from the specifications you provided, they don't have constant current control built in. You need to power them from a power supply that can provide 700mA constant current and be controlled from an output of the Duet.
        • Thierry14undefined Thierry14 marked this topic as a question
        • Thierry14undefined Thierry14 marked this topic as a regular topic
        • Thierry14undefined Thierry14 has marked this topic as solved
