Firmware 3.5.x installation
Which tags do I need to use for all the above branches on Duet3_MB6HC?
Regards
Siva -
@Siva The latest tag is https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0-beta.4
However, that will be behind the 3.5-dev branch, as there have been commits since that release, and we don't do nightlies.If you want to compile it yourself, yes, you need all of those, on the branch shown. eg
git clone https://github.com/Duet3D/RepRapFirmware.git --branch 3.5-dev
git clone https://github.com/Duet3D/CANlib.git --branch 3.5-dev
git clone https://github.com/Duet3D/CoreN2G.git --branch 3.5-dev
git clone https://github.com/Duet3D/FreeRTOS.git --branch 3.4-dev
git clone https://github.com/Duet3D/RRFLibraries.git --branch 3.5-dev
git clone https://github.com/Duet3D/DuetWiFiSocketServer.git --branch devIan
@droftarts Thanks for confirming, I seeing the following error
@Siva For the DuetWiFiSocketServer errors, as it says in the docs, and in the table you posted in your first post:
this project must be present but you don't need to build it
For the makefile error, I'm not sure. One for @dc42 maybe. Did you select the 6HC build configuration? Build RRF for your board by selecting the Build configuration from the hammer icon drop-down in the menu bar at the top of the screen.
Edit: Click on the 'Console' tab, it should show more information about the error.
I didn't build "DuetWifiSocketServer" just added to the project. This get triggered when I build "RepRapFirmware->Duet3_MB6HC" as shown below
here is console output
12:54:00 **** Incremental Build of configuration Duet3_MB6HC for project RepRapFirmware **** make -j8 all Building target: Duet3Firmware_MB6HC.elf Invoking: Cross G++ Linker arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreN2G\SAME70_CAN_SDHC_USB_RTOS" -L"C:\Eclipse\Firmware\RRFLibraries\SAME70_RTOS" -L"C:\Eclipse\Firmware\FreeRTOS\SAME70" -L"C:\Eclipse\Firmware\CANlib\SAME70_RTOS" --specs=nosys.specs -Os -Wl,--gc-sections -Wl,--fatal-warnings -Wl,--no-warn-rwx-segment -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -T"C:\Eclipse\Firmware\RepRapFirmware\src\Hardware\SAME70\same70q20b_flash.ld" -Wl,-Map,"C:\Eclipse\Firmware\RepRapFirmware\Duet3_MB6HC/Duet3Firmware_MB6HC.map" -o "Duet3Firmware_MB6HC.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ./src/libcpp/eh_alloc.o ./src/libcpp/vterminate.o ./src/libc/atoi.o ./src/libc/errno.o ./src/libc/memcmp.o ./src/libc/memcpy.o ./src/libc/memmove.o ./src/libc/memset.o ./src/libc/nano-mallocr.o ./src/libc/strptime.o ./src/bossa/Applet.o ./src/bossa/BossaFlash.o ./src/bossa/Device.o ./src/bossa/EefcFlash.o ./src/bossa/Flasher.o ./src/bossa/Samba.o ./src/bossa/WordCopyApplet.o ./src/bossa/WordCopyArm.o ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o ./src/Storage/CRC16.o ./src/Storage/CRC32.o ./src/Storage/EmbeddedFiles.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/SBC/DataTransfer.o ./src/SBC/SbcInterface.o ./src/PrintMonitor/PrintMonitor.o ./src/Platform/ArrayHandle.o ./src/Platform/Event.o ./src/Platform/Heap.o ./src/Platform/Logger.o ./src/Platform/MessageBox.o ./src/Platform/OutputMemory.o ./src/Platform/Platform.o ./src/Platform/PortControl.o ./src/Platform/RepRap.o ./src/Platform/StringHandle.o ./src/Platform/Tasks.o ./src/Platform/UniqueId.o ./src/ObjectModel/GlobalVariables.o ./src/ObjectModel/ObjectModel.o ./src/ObjectModel/Variable.o ./src/Networking/MulticastDiscovery/MulticastResponder.o ./src/Networking/MulticastDiscovery/fgmc_protocol.o ./src/Networking/MQTT/MQTT_C/src/mqtt.o ./src/Networking/MQTT/MqttClient.o ./src/Networking/MQTT/mqtt_pal.o ./src/Networking/LwipEthernet/Lwip/src/netif/bridgeif.o ./src/Networking/LwipEthernet/Lwip/src/netif/bridgeif_fdb.o ./src/Networking/LwipEthernet/Lwip/src/netif/ethernet.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6_ble.o ./src/Networking/LwipEthernet/Lwip/src/netif/lowpan6_common.o ./src/Networking/LwipEthernet/Lwip/src/netif/slipif.o ./src/Networking/LwipEthernet/Lwip/src/netif/zepif.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/dhcp6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ethip6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/icmp6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/inet6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6_addr.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/ip6_frag.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/mld6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv6/nd6.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/autoip.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/dhcp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/etharp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/icmp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/igmp.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4_addr.o ./src/Networking/LwipEthernet/Lwip/src/core/ipv4/ip4_frag.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp_alloc.o ./src/Networking/LwipEthernet/Lwip/src/core/altcp_tcp.o ./src/Networking/LwipEthernet/Lwip/src/core/def.o ./src/Networking/LwipEthernet/Lwip/src/core/dns.o ./src/Networking/LwipEthernet/Lwip/src/core/inet_chksum.o ./src/Networking/LwipEthernet/Lwip/src/core/init.o ./src/Networking/LwipEthernet/Lwip/src/core/ip.o ./src/Networking/LwipEthernet/Lwip/src/core/mem.o ./src/Networking/LwipEthernet/Lwip/src/core/memp.o ./src/Networking/LwipEthernet/Lwip/src/core/netif.o ./src/Networking/LwipEthernet/Lwip/src/core/pbuf.o ./src/Networking/LwipEthernet/Lwip/src/core/raw.o ./src/Networking/LwipEthernet/Lwip/src/core/stats.o ./src/Networking/LwipEthernet/Lwip/src/core/sys.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp_in.o ./src/Networking/LwipEthernet/Lwip/src/core/tcp_out.o ./src/Networking/LwipEthernet/Lwip/src/core/timeouts.o ./src/Networking/LwipEthernet/Lwip/src/core/udp.o ./src/Networking/LwipEthernet/Lwip/src/apps/netbiosns/netbiosns.o ./src/Networking/LwipEthernet/Lwip/src/apps/mdns/mdns.o ./src/Networking/LwipEthernet/Lwip/src/api/api_lib.o ./src/Networking/LwipEthernet/Lwip/src/api/api_msg.o ./src/Networking/LwipEthernet/Lwip/src/api/err.o ./src/Networking/LwipEthernet/Lwip/src/api/if_api.o ./src/Networking/LwipEthernet/Lwip/src/api/netbuf.o ./src/Networking/LwipEthernet/Lwip/src/api/netdb.o ./src/Networking/LwipEthernet/Lwip/src/api/netifapi.o ./src/Networking/LwipEthernet/Lwip/src/api/sockets.o ./src/Networking/LwipEthernet/Lwip/src/api/tcpip.o ./src/Networking/LwipEthernet/GMAC/ethernet_sam.o ./src/Networking/LwipEthernet/LwipEthernetInterface.o ./src/Networking/LwipEthernet/LwipSocket.o ./src/Networking/ESP8266WiFi/WiFiInterface.o ./src/Networking/ESP8266WiFi/WiFiSocket.o ./src/Networking/ESP8266WiFi/WifiFirmwareUploader.o ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkClient.o ./src/Networking/NetworkInterface.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/FiveBarScaraKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/RoundBedKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/HeightControl/HeightController.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/AxisShaper.o ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/ExtruderShaper.o ./src/Movement/Move.o ./src/Movement/MoveSegment.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o ./src/Libraries/sha1/sha1.o ./src/Libraries/sd_mmc/ctrl_access.o ./src/Libraries/sd_mmc/sd_mmc.o ./src/Libraries/sd_mmc/sd_mmc_mem.o ./src/Libraries/sd_mmc/sd_mmc_spi.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o ./src/LedStrips/DotStarLedStrip.o ./src/LedStrips/LedStripBase.o ./src/LedStrips/LedStripManager.o ./src/LedStrips/LocalLedStrip.o ./src/LedStrips/NeoPixelLedStrip.o ./src/LedStrips/RemoteLedStrip.o ./src/InputMonitors/InputMonitor.o ./src/Heating/Sensors/AdditionalOutputSensor.o ./src/Heating/Sensors/BME280.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RemoteSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SensorWithPort.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Heater.o ./src/Heating/HeaterMonitor.o ./src/Heating/LocalHeater.o ./src/Heating/RemoteHeater.o ./src/Hardware/Spi/SharedSpiClient.o ./src/Hardware/Spi/SharedSpiDevice.o ./src/Hardware/Spi/SpiDevice.o ./src/Hardware/SAME70/Ethernet/ksz8081rna/ethernet_phy.o ./src/Hardware/SAME70/Ethernet/GmacInterface.o ./src/Hardware/SAME70/Devices.o ./src/Hardware/SAME70/Main.o ./src/Hardware/ExceptionHandlers.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o ./src/Hardware/NonVolatileMemory.o ./src/Hardware/SoftwareReset.o ./src/GPIO/GpInPort.o ./src/GPIO/GpOutPort.o ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/ExpressionParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o ./src/GCodes/CollisionAvoider.o ./src/GCodes/GCodeException.o ./src/GCodes/GCodeFileInfo.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/GCodes5.o ./src/GCodes/GCodes6.o ./src/GCodes/GCodes7.o ./src/GCodes/KeepoutZone.o ./src/GCodes/ObjectTracker.o ./src/GCodes/RestorePoint.o ./src/GCodes/StraightProbeSettings.o ./src/GCodes/TriggerItem.o ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o ./src/Fans/Fan.o ./src/Fans/FansManager.o ./src/Fans/LocalFan.o ./src/Fans/RemoteFan.o ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/LocalZProbe.o ./src/Endstops/RemoteZProbe.o ./src/Endstops/StallDetectionEndstop.o ./src/Endstops/SwitchEndstop.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeEndstop.o ./src/Config/Pins.o ./src/Comms/AuxDevice.o ./src/Comms/FirmwareUpdater.o ./src/Comms/PanelDueUpdater.o ./src/ClosedLoop/ClosedLoop.o ./src/CAN/CanDriversData.o ./src/CAN/CanInterface.o ./src/CAN/CanMessageGenericConstructor.o ./src/CAN/CanMotion.o ./src/CAN/CommandProcessor.o ./src/CAN/ExpansionManager.o ./src/Accelerometers/Accelerometers.o ./src/Accelerometers/LIS3DH.o ./src/RepRapFirmware.o ./src/Version.o -lCoreN2G -lRRFLibraries -lFreeRTOS -lCANlib -lsupc++ -Wl,--end-group -lm Finished building target: Duet3Firmware_MB6HC.elf Generating binary file arm-none-eabi-objcopy -O binary "C:\Eclipse\Firmware\RepRapFirmware\Duet3_MB6HC/Duet3Firmware_MB6HC.elf" "C:\Eclipse\Firmware\RepRapFirmware\Duet3_MB6HC/Duet3Firmware_MB6HC.bin" && CrcAppender "C:\Eclipse\Firmware\RepRapFirmware\Duet3_MB6HC/Duet3Firmware_MB6HC.bin" c:/program files/gnu arm eclipse/build tools/2.6-201507152002/bin//sh: CrcAppender: not found makefile:126: recipe for target 'post-build' failed make[1]: [post-build] Error 127 (ignored) 12:54:05 Build Failed. 1 errors, 0 warnings. (took 5s.62ms)
I don't see "crcAppender.exe" here
but it's already included in the project
It seems it's looking in the wrong directory.
I didn't get any errors for the following setup:
CANlib->SAME70_RTOS
CoreN2G->SAME70_CAN_SDHC_USB_RTOS
FreeRTOS->SAME70
RRFLibraries->SAM70_RTOS -
@Siva said in Firmware 3.5.x installation:
You have included it in the project, but its location also needs to be in your PATH. From the build instructions:
Building RepRapFirmware lately requires a tool called crc32appender to be in the user's PATH as it will be called at the end of the compilation process.
(https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware#additional-tools)Modify your PATH environment variable to include the usr/bin folder of the MSYS2 installation (e.g. C:\msys64\usr\bin), and to include the path to crc32appender.exe (see earlier note).
(Step 5 https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware#instructions-for-building-under-windows)Ian
@droftarts Thanks it's building without any errors.
Thanks
Siva -
@Siva Hello, may I venture to ask you a question about writing compilation, I ran into some troubles.
