    Ir probe all of a sudden triggering early
    IR Height Sensor
    • ageisundefined
      ageis
      This post is deleted!
        droftarts administrators @ageis
        @ageis said in Ir probe all of a sudden triggering early:
        Today when I homed the y axis it just trigged immediately.
        Do you mean Z? That's what the probe is set up for. And it sounds like the probe is responding correctly. If it's Y that isn't homing, check the endstop isn't disconnected, then test the endstop is working correctly when you press it, by sending M119 before you press it, and again while you are pressing it.
