    Hikvision Network camera
    Duet Web Control
    • amimafeundefined
      amimafe
      I would like to know if it is possible to integrate a HIKVISION camera to DWC. I can access it from the IP in the browser but I can't do it from the DWC.
      Thank you!
        droftarts administrators @amimafe
        @amimafe It depends which Hikvision camera you have. It needs to have the facility to return a static JPEG image in response to a HTTP request. See https://www.ispyconnect.com/camera/hikvision
        If you are running your Duet connected to an SBC (Raspberry Pi), you have more options. See https://docs.duet3d.com/en/User_manual/Reference/DWC_webcam
        amimafeundefined 1 Reply Last reply Reply Quote 0
        • amimafeundefined
          amimafe @droftarts
          @droftarts Sí, es el modelo DS-2CD1027G0-L pero no consigo que muestre ninguna imágen. Estoy poniendo la URL que especifica el fabricante:
          http://user.pass@192.168.1.64:80/Streaming/channels/1/picture
          Any idea?
            @amimafe According to the ispyconnect website, the DS-2CD1027G0-L outputs FFMPEG using an RTSP camera video stream. So it cannot be embedded in a webpage, or DWC, without using third-party converters like VLC, or by using an intermediate media server (eg raspberry pi) to convert the stream to something a browser can understand.
            From https://docs.duet3d.com/en/User_manual/Reference/DWC_webcam
            Important: You must choose a camera that has the facility to return a static JPEG image in response to a HTTP request. Not all IP cameras have this facility. Sadly, none of the major browsers supports including a RTSP camera video stream in a web page.
            • amimafeundefined amimafe marked this topic as a question
            • amimafeundefined amimafe has marked this topic as solved
