    Duet3 mini5+ pwm frequency limitation
    Laser Cutters
    • jimakronundefined
      jimakron
      I have a laser that has a frequency from 0-20khz. Is there any limitations from the duet3 mini5+ board that would keep me from using the full 20khz?
        dc42 administrators @jimakron
        @jimakron yes you can use 20kHz. The available range is about 3Hz to 65kHz.
        jimakronundefined 1 Reply Last reply Reply Quote 1
        • jimakronundefined
          jimakron @dc42
          @dc42 Thank you!
          • jimakronundefined jimakron marked this topic as a question
          • jimakronundefined jimakron has marked this topic as solved
