    Unable to setup an endstop for a syringe axis on Duet 2 Wifi
    CNC
    • maletecsciundefined
      maletecsci
      We are using the Duet 2 Wifi for a threedimensional 3D printer, excepting that we added a 4th axis. It has a stepper motor with a syringe on it, and an endstop too (connected on the E0 pins). We're having trouble setting up that endstop, for making the homing process. We accomplished to move the E0 motor when doing the "homeall" process, but when the endstop gets clicked the motor doesn't stop.
      this is the configuration of the homeall:
      G91 ; relative positioning
      G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-205 F360 ; move Z down stopping at the endstop
      T0 ; Select tool 0 for use (syringe) this enable the commands in Dashboard
      G1 H1 E0-40 F60 ; move E0 (Syringe) 10mm down in 60mm/min = 1mm/s (first pass)
      ;M18 E0 ; stop E0 axis when it hits the endstop
      G90 ; absolute positioning
      ;G92 Z0 E0 ; set Z position to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      Thank you for reading, waiting for your answer!
        jay_s_uk @maletecsci
        @maletecsci you can't home an extruder.
        If you want to move it to a set position, map the drive to a different axis, e.g. U and then carry out the move. Then map it back as the extruder
        maletecsciundefined 1 Reply Last reply Reply Quote 0
          maletecsci @jay_s_uk
          @jay_s_uk Hi! It's my first time using Duet2, so if you could help me a little more would be great. From your answer, I understood that i should modify the config.g and create a new axis. But, where do i connect the drive? And how do i map it with the new axis?
          Here is my config.g if it's usefull
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed May 31 2023 17:09:22 GMT-0300 (hora estándar de Argentina)
          M550 P"My Printer" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P1 S0 ; physical drive 1 goes forwards
          M584 X0 Y1 Z2 E03 ; set drive mapping
          M350 X256 Y256 Z256 I0 ; configure microstepping without interpolation
          M350 E256 I1 ; configure microstepping with interpolation
          M92 X12800.00 Y12800.00 Z12800.00 E12800.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X0 Y0 Z0 E00 S1 ; set axis minima
          M208 X288 Y147 Z38 E035 S0 ; set axis maxima
          M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin ystop
          M574 E01 S1 P"e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on E0 via pin e0stop
          M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M563 P0 D0 F0 ; define tool 0
          Thank you for answering so quickly! Looking forward for yor reply.
            @maletecsci i think it may be enough to set up the same driver as E and U, so something like
            M584 X0 Y1 Z2 E3 U3 P3 with the U axis settings matching the E settings in the rest of the driver settings
            That will hide the U axis by default.
            Then in your homing file at the beginning, set M584 P4. That will unhide the U axis, allowing you to home it using G1 H1 Ux etc.
            Then just rehide the U axis at the end M584 P3
