    First Layer weird Z height change? Help!
    • Peacemaker105undefined
      Peacemaker105
      Hey all, I've been having this weird issue lately, not sure what the hell has caused it but every time I start a print after homing it will start at Z=0.28
      Z offset is set to piece of paper at Z=0. I can manually step the z axis back down to 0 after starting and get a good first layer but then the second layer goes to 0.48. There is nothing in the start G-Code except Home and Load height map.
      I tried even tried deleting height map and not loading it at all and it still does it. I tried another slicer and it still does it. Something isn't right...
      I also updated firmware to the latest and redid all my config to no avail.
      Trying to think back to when it first started happening and i can't think of anything i would have done to make this happen. I use to use the same height map for months on end before re-probing. I think i ran a mesh comp to update the height map one day and i feel it was dramas ever since. Just weird it happens with or without height map loaded..
      Any ideas as to what could be the issue would be greatly appreciated. I'm ready to burn it... lol
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Jul 18 2023 14:13:53 GMT+0800 (Australian Western Standard Time)
      M575 P1 S1 B57600                                       ; enable support for PanelDue
      G90                                                     ; send absolute coordinates...
      M83                                                     ; ...but relative extruder moves
      M550 P"Seckit Go"                                       ; set printer name
      M669 K1                                                 ; select CoreXY mode
      M552 S1                                                 ; enable network
      M586 P0 S1                                              ; enable HTTP
      M586 P1 S0                                              ; disable FTP
      M586 P2 S0                                              ; disable Telnet
      M569 P0 S1                                            ; physical drive 0 goes forwards
      M569 P1 S1                                            ; physical drive 1 goes forwards
      M569 P2 S1                                             ; physical drive 2 goes backwards
      M569 P3 S1                                              ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
      M92 X199.80 Y199.20 Z400.00 E396.88                       ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E7200.00                     ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E72000.00               ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z20.00 E250.00                     ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30                         ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                 ; Set idle timeout
      M572 D0 S0.03                                                ; Set idle timeout
      M208 X0 Y0 Z0 S1                                        ; set axis minima
      M208 X310 Y325 Z350 S0                                  ; set axis maxima
      M574 X1 S3                                              ; configure sensorless endstop for low end on X
      M574 Y1 S3                                              ; configure sensorless endstop for low end on Y
      M574 Z1 S2                                              ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater4"                                  ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                     ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-20 Y15 Z1.55                                     ; set Z probe trigger value, offset and trigger height
      M557 X30:270 Y40:325 S40                                ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                   ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.513 K0.326:0.000 D4.45 E1.35 S0.80 B0                                        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                 ; map heated bed to heater 0
      M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e1heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 R2.796 K0.420:0.132 D5.93 E1.35 S1.00 B0 V23.9                                        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                            ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                    ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan1" Q500                                    ; create fan 2 on pin fan1 and set its frequency
      M106 P2 S0 H1 T45                                       ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H1 F0                     ; define tool 0
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Jul 18 2023 14:13:54 GMT+0800 (Australian Western Standard Time)
      M400                    ; make sure everything has stopped before we make changes
      M913 X40 Y40            ; drop motor currents to 50%
      M400
      ;M915 X Y S5
      M203 X5000.00 Y5000.00 Z180.00 E72000.00               ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                     ; set accelerations (mm/s^2)
      G1 H2 Z5 F10000          ; lift Z relative to current position
      ;G1 H1 X-315 Y-315 F8000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 S1 X-315 F4000             ; home X axis
      G1 X5 F4000          ; go back a few mm
      G1 S1 Y-315 F4000             ; home Y axis
      G1 Y5 F4000          ; go back a few mm
      ;G1 H1 X-315 F360        ; move slowly to X axis endstop once more (second pass)
      ;G1 H1 Y-315             ; then move slowly to Y axis endstop
      M400                    ; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100          ; motor currents back to 100%
      M400
      G1 X175 Y175 F10000        ; go to first bed probe point and home Z
      M203 X18000.00 Y18000.00 Z180.00 E72000.00               ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z20.00 E250.00                     ; set accelerations (mm/s^2)
      G30                     ; home Z by probing the bed
      ;G91                    ; relative positioning
      ;G1 Z5 F100             ; lift Z relative to current position
      ;G90                    ; absolute positioning
        Post your config-override.g and your slicer start gcode.
        Also please share the first 100 lines or so of a sliced gcode file.
        @Peacemaker105 said in First Layer weird Z height change? Help!:
        What layer height are you printing with?
