    [3.5.0-beta.4] OM docs not available (DuetAPI.xml not found)
    Duet Web Control
    • marvineerundefined
      marvineer
      I think I have another possible bug for @chrishamm to look at:
      The Object Model Browser integrated plugin shows this error instead of the description:
      However, ls /opt/dsf/sd/www/ -la yields the following output, so the file is indeed not there:
      total 7968
      drwxr-xr-x 6 dsf    dsf       4096 Jul 20 12:09 .
      drwxr-xr-x 7 marvin marvin    4096 Jun 22 20:39 ..
      -rw-rw-r-- 1 dsf    dsf      12108 Jun 12  2022 BtnCmd.01c40732.css
      -rw-rw-r-- 1 dsf    dsf       2649 Jun 12  2022 BtnCmd.01c40732.css.gz
      -rw-rw-r-- 1 dsf    dsf     814847 Jun 12  2022 BtnCmd.644583ff.js
      -rw-rw-r-- 1 dsf    dsf     178402 Jun 12  2022 BtnCmd.644583ff.js.gz
      -rw-rw-r-- 1 dsf    dsf    2431423 Jun 12  2022 BtnCmd.644583ff.js.map
      -rw-rw-r-- 1 dsf    dsf     533856 Jun 12  2022 BtnCmd.644583ff.js.map.gz
      -rw-rw-r-- 1 dsf    dsf      12074 Jun  3  2022 BtnCmd.afac96e1.css
      -rw-rw-r-- 1 dsf    dsf       2642 Jun  3  2022 BtnCmd.afac96e1.css.gz
      -rw-rw-r-- 1 dsf    dsf     811522 Jun  3  2022 BtnCmd.c6c8d8ef.js
      -rw-rw-r-- 1 dsf    dsf     177968 Jun  3  2022 BtnCmd.c6c8d8ef.js.gz
      -rw-rw-r-- 1 dsf    dsf    2424615 Jun  3  2022 BtnCmd.c6c8d8ef.js.map
      -rw-rw-r-- 1 dsf    dsf     532933 Jun  3  2022 BtnCmd.c6c8d8ef.js.map.gz
      drwxr-xr-x 2 dsf    dsf       4096 Jul 20 12:09 css
      drwxr-xr-x 2 dsf    dsf       4096 Jul 20 12:09 fonts
      drwxr-xr-x 3 dsf    dsf       4096 Mar 18  2022 img
      -rw-rw-r-- 1 dsf    dsf       1553 Jun  9 13:04 index.html
      drwxr-xr-x 2 dsf    dsf       4096 Jul 20 12:09 js
      -rw-rw-r-- 1 dsf    dsf        565 Jun  9 13:04 manifest.json
      -rw-rw-r-- 1 dsf    dsf         24 Jun  9 13:04 robots.txt
      -rw-rw-r-- 1 dsf    dsf       2215 Jun  9 13:04 service-worker.js
      -rw-rw-r-- 1 dsf    dsf       4417 Jun  9 13:04 service-worker.js.map
      -rw-rw-r-- 1 dsf    dsf      14450 Jun  9 13:04 workbox-5b385ed2.js
      -rw-rw-r-- 1 dsf    dsf     137525 Jun  9 13:04 workbox-5b385ed2.js.map
      I tried reinstalling DWC with sudo apt --reinstall install duetwebcontrol but this did not change anything.
      Only manually moving the file from the latest DWC release zip to the above location solved the problem.
      Does anyone have any ideas or am I the only one missing this file after installation?
      Thanks in advance!
      • chrishammundefined
        chrishamm administrators @marvineer
        @marvineer Yes, I can confirm this, it's missing in 3.5-b4 due to an error in the GitHub build workflow. I've already fixed this for the next version 3.5.0-rc.1
        Duet software engineer
        • marvineerundefined marvineer marked this topic as a question
        • marvineerundefined marvineer has marked this topic as solved
