    Problem with 12V duet 3d 6hc v1.02
    Hardware dev
    658
    • Italiano85undefined
      Italiano85
      @T3P3Tony @dc42
      After a month of inactivity, today I try to turn the printer back on but after about 5 minutes of printing the machine stops and a series of "Warning: 12V under-voltage event (x.x V)" errors appear.
      I have tried unplugging all motors, all sensors and all fans and the voltage remains at 11.8V.
      I have already mounted a new power supply that I had from 24V but the problem has not been solved
      I tried with the M122 command to receive diagnostic information.
      Warning: 12V under-voltage event (9.4V)
      24/7/2023, 17:21:45 	m122
      RepRapFirmware for Duet 3 MB6HC version 3.5.0-beta.4 (2023-06-08 23:41:30) running on Duet 3 MB6HC v1.02 or later (standalone mode)
      Board ID: 08DJM-9P63L-DJ3T0-6J1F8-3SN6S-TV3BB
      Used output buffers: 3 of 40 (18 max)
      Static ram: 155012
      Dynamic ram: 122036 of which 0 recycled
      Never used RAM 68944, free system stack 204 words
      Tasks: NETWORK(1,ready,34.6%,182) ETHERNET(5,nWait,0.1%,568) HEAT(3,nWait,0.0%,335) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,820) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,344) TMC(4,nWait,1.0%,61) MAIN(1,running,64.1%,444) IDLE(0,ready,0.2%,30), total 100.0%
      Owned mutexes:
      Last reset 00:00:48 ago, cause: power up
      Last software reset at 2023-07-24 16:54, reason: User, Gcodes spinning, available RAM 65140, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU temperature: min 28.0, current 37.2, max 37.3
      Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 4.0, current 10.2, max 10.3, under voltage events: 4
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 19, mspos 8, reads 32059, writes 55 timeouts 0
      Driver 1: standstill, SG min 19, mspos 0, reads 32059, writes 55 timeouts 0
      Driver 2: standstill, SG min 0, mspos 8, reads 32060, writes 55 timeouts 0
      Driver 3: standstill, SG min 19, mspos 8, reads 32060, writes 55 timeouts 0
      Driver 4: standstill, SG min 19, mspos 8, reads 32060, writes 55 timeouts 0
      Driver 5: standstill, SG min 19, mspos 8, reads 32060, writes 55 timeouts 0
      Date/time: 2023-07-24 17:21:42
      Slowest loop: 4.65ms; fastest: 0.07ms
      === Storage ===
      Free file entries: 20
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 2.4ms, write time 0.0ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      === DDARing 0 ===
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 3 -1 -1 -1, ordering errs 0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000000
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 429, received 569, lost 0, boc 0
      Longest wait 1ms for reply type 6031, peak Tx sync delay 58278, free buffers 50 (min 49), ts 242/239/0
      Tx timeouts 0,0,2,0,0,0 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 8.13ms; fastest: 0.03ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      Interface state: active
      Error counts: 0 0 0 1 0 0
      Socket states: 5 2 2 2 2 0 0 2
      = WiFi =
      Interface state: disabled
      Module is disabled
      === Multicast handler ===
      Responder is inactive, messages received 0, responses 0
      Warning: 12V under-voltage event (9.2V)
      How can I do it, is it a firmware problem (3.5.0 BETA.4) or is it a card problem?
      Thanks in advance.
        It would seem that the 12v regulator is damaged.
        Can you grab some photos of the board?
        When and where was the board purchased?
        Italiano85undefined 1 Reply Last reply Reply Quote 0
          Italiano85 @Phaedrux
          @Phaedrux
          I bought the board in Italy from COMPASS DHM PROJECT on 03/23/2023, this is the replacement for the first defective one that was delivered to me in May 2023 after a warranty replacement procedure.
            dc42 administrators @Italiano85
            @Italiano85 said in Problem with 12V duet 3d 6hc v1.02:
            11.8V is within tolerance; but 10.2V as reported by your M122 listing is out of tolerance. Were any 12V fans or other 12V devices connected to the Duet when you ran that M122 report?
              Italiano85 @dc42
              Today I tried unplugging everything and keeping the card on for hours.
              This is the result.
              25/7/2023, 21:22:03 	m122
              Used output buffers: 3 of 40 (31 max)
              Error in macro line 33 while starting up: Response timeout: CAN addr 40, req type 6018, RID=0
              Static ram: 155012
              Dynamic ram: 121896 of which 0 recycled
              Never used RAM 66228, free system stack 208 words
              Tasks: NETWORK(1,ready,41.5%,153) ETHERNET(5,nWait,0.0%,321) HEAT(3,nWait,0.0%,329) Move(4,nWait,0.0%,332) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,343) TMC(4,nWait,8.1%,59) MAIN(1,running,50.4%,444) IDLE(0,ready,0.0%,30), total 100.0%
              Owned mutexes:
              Last reset 06:56:47 ago, cause: power up
              Error status: 0x00
              MCU temperature: min 38.6, current 38.9, max 39.6
              Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 0.6, current 12.1, max 12.3, under voltage events: 2
              Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/64/0, gc cycles 0
              Driver 0: standstill, SG min n/a, mspos 8, reads 7823, writes 11 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 0, reads 7824, writes 11 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 8, reads 7824, writes 11 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 8, reads 7824, writes 11 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 8, reads 7824, writes 11 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 8, reads 7823, writes 11 timeouts 0
              Date/time: 2023-07-25 21:22:03
              Slowest loop: 5.19ms; fastest: 0.07ms
              === Storage ===
              SD card longest read time 2.3ms, write time 0.0ms, max retries 0
              === DDARing 0 ===
              === DDARing 1 ===
              === CAN ===
              Messages queued 41222, received 0, lost 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 22901/0/0
              Tx timeouts 0,0,22901,0,0,18321 last cancelled message type 30 dest 127
              === Network ===
              Slowest loop: 4.03ms; fastest: 0.03ms
              = Ethernet =
              Error counts: 0 0 0 0 0 0
              = WiFi =
              Module is disabled
                @Italiano85 that looks OK but doesn't prove much because the "min 0.6V" will most likely have been measured just after power up. Best thing to do is power up, wait a few seconds and run M122. This will reset the min and max values for the 12V rail after displaying them. Run M122 again to check that the min value has been reset. Then leave it on for a day, then run M122 again.
                The 12V rail on the 6HC feeds the stepper drivers, the 12V_OUT connector, and any banks of three OUT ports that have the jumper set to 12V.
                  Italiano85 @dc42
                  @dc42 The result of the M122 that I posted above was the tenth of the session since it was on.
                    @Italiano85 thanks, in that case we need to replace your board. Please email warranty@duet3d.com and cc your supplier. Include a link to this thread in your email.
