IP address setting
M350 X128 Y128 Z128:128:128 E128:128 I1 ; configure microstepping with interpolation M92 X1600 Y1600 Z12800:12800:12800 E3936:6400 ; steps per mm E1:800 E2:837 M566 X540 Y540 Z56:56:56 E480:480 ; maximum instantaneous speed changes mm/min M203 X10000 Y10000 Z1800:1800:1800 E15000:15000 ; maximum speeds (mm/s) M201 X2000 Y2000 Z100:100:100 E1000:3000 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z800 E800 I50 ; set motor currents (mA) and idle %
You should remove the extra parameters from the Z axis. You only need to set the settings for the axis once rather than each motor.
example: Z100100 should be just Z100
Extruders are different and must be set for each extruder motor since they are independant.
