M106 not enabling fans on startup
I'm configuring some fans with M106 P0 S255 but they don't run on startup, they work fine if I send that command later though. Do you see anything in my code that might be causing that?
; Configuration file for Duet 3 MB 6XD (firmware version 3.4.1) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 09 2022 12:10:26 GMT-0600 (Central Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"my printer" ; set printer name ; Declare global variables if !exists(global.T1ActuationDist) global T1ActuationDist = 17 global T2ActuationDist = {global.T1ActuationDist} global T12FeedRt = 1000 global T1ZOffset = -7.55 global T2ZOffset = {global.T1ZOffset} global layerSpeed = 2400 global PrimaryFanSpeed = 0 global mosqFanSpeed = 0 global vacZone1Pin = "1.out2" global vacZone2Pin = "2.out0" global vacZone3Pin = "2.out1" global vacZone4Pin = "2.out2" else set global.T1ActuationDist = 17 set global.T2ActuationDist = {global.T1ActuationDist} set global.T12FeedRt = 1000 set global.T1ZOffset = -7.55 set global.T2ZOffset = {global.T1ZOffset} set global.layerSpeed = 2400 set global.PrimaryFanSpeed = 0 set global.mosqFanSpeed = 0 set global.vacZone1Pin = "1.out2" set global.vacZone2Pin = "2.out0" set global.vacZone3Pin = "2.out1" set global.vacZone4Pin = "2.out2" ; Wait a moment for the CAN expansion boards to start G4 S2 ; Drive Setup M18 ; disable steppers to disable old axes config ; Drive setup ; TX:X:X:X Min stp pls width, stp ple interval, dir setup time, dir hold time, in microseconds M569 P121.0 S1 R1 T1:2:1:1 ; physical drive X dc42 recommends T1:1:0.5:0 but we were using T1:2:1:1 for everything, 0.75:1.5:0.025:1 might make y stall M569 P0.0 S1 R1 T1:2:1:1 ; physical drive Y1 M569 P0.1 S1 R1 T1:2:1:1 ; physical drive Y2 M569 P0.2 S0 R1 T1:2:1:1 ; physical drive Z1 M569 P0.3 S0 R1 T1:2:1:1 ; physical drive Z2 M569 P0.4 S0 R1 T1:2:1:1 ; physical drive Z3 M569 P0.5 S0 R1 T1:2:1:1 ; physical drive Z4 M569 P123.0 S0 R0 ; physical drive E0 Primary Extruder M569 P3.1 S1 R1 ; physical drive E1 Mosquito 1 extruder M569 P3.2 S1 R1 ; physical drive E2 Mosquito 2 extruder M569 P4.0 S1 R1 ; physical drive actuator 1 M569 P4.1 S1 R1 ; physical drive actuator 2 G4 S1 ; wait for drive to setup ; Drive mapping M584 X121.0 ; set drive mapping for x axis M584 Y0.0:0.1 ; set drive mapping for y axis M584 Z0.2:0.3:0.4:0.5 ; set drive mapping for z axes M584 E123.0:3.1:3.2 ; set drive mapping for extruder axes M584 U4.0 ; set drive mapping for mosquito actuator 1 M584 V4.1 ; set drive mapping for mosquito actuator 2 G4 S1 ; wait for drives to be mapped to letters ; Drive config M350 E16:16:16 U1 V1 ; configure microstepping with interpolation M92 X128 Y128 Z6400 E224.6:410:410 U200 V200 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120:120:120 U900 V900 P1 ; set maximum instantaneous speed changes (mm/min) M203 X42000 Y76050 Z3000 E9000:1200:1200 U300 V300 ; set maximum speeds (mm/min) was Z400 M201 X3000 Y3000 Z8209 E3000:3000:3000 U100 V100 ; set accelerations (mm/s^2) was Z8209 X25635 Y19770 z was 2000 M906 E2700:600:600 U500 V500 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Brakes M569.7 P0.2 C"out3" S100 ; driver 2 on board 6XD uses port out3 to control the brake M569.7 P0.3 C"out4" S100 ; driver 3 on board 6XD uses port out4 to control the brake M569.7 P0.4 C"out5" S100 ; driver 4 on board 6XD uses port out5 to control the brake M569.7 P0.5 C"out6" S100 ; driver 5 on board 6XD uses port out6 to control the brake ; Endstops M574 X1 S1 P"3.io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 3.io0.in M574 Y1 S1 P"0.io1.in+io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in and io2.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z M574 U1 S1 P"3.!io3.in" ; configure actuator 1 endstop, high end, microswitch M574 V1 S1 P"3.!io5.in" ; configure actuator 2 endstop, high end, microswitch ; Hobby Servos M950 S0 C"3.io1.out" ; create servo 1 output on 3.io2 for mosquito acutator 1 M950 S1 C"3.io4.out" ; create servo 1 output on 3.io3 for mosquito acutator 2 ;Bed Leveling M671 X1205:1205:-285.1:-285.1 Y-207.2:1451.4:1451.4:-207.2 S1.0 P5 F1.0 ;Define Z screw X Y locations, max correction, pitch, fudge factor ; Axis Limits M208 X0 Y0 Z-10 U0 V0 W0 S1 ; set axis minima M208 X1208 Y1195 Z1200 U17 V17 W100 S0 ; set axis maxima ; Z-Probe ; servo pin defined in fan accessories section ; create servo pin for BLTouch M558 P8 C"!0.io8.in" H5 F100:50 T20000 R1 A5 S0.03 ; set Z probe type and the dive height + speeds G31 P1000 X47.8 Y-15.2 Z5.8 ; set Z probe trigger value, offset and trigger height for 1mm nozzle M557 X0:1200 Y0:1200 P10:10 ; define mesh grid ; Heaters M308 S0 P"0.temp0" Y"PT1000" A"Bed A" ; configure bed A sensor 0 as thermistor on pin temp0 M308 S9 P"0.temp2" Y"PT1000" A"Bed B" ; configure bed B sensor 9 as thermistor on pin temp2 M950 H0 C"0.out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang for bed and set pwm M140 P0 H0 S0 R0 ; bed heater 0 uses heater 0 M143 H0 S255 P0 T0 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S1 P"0.temp1" Y"PT1000" A"Chamber A" ; configure chamber A sensor 1 as thermistor on pin temp1 M308 S10 P"0.temp3" Y"PT1000" A"Chamber B" ; configure chamber B sensor 10 as thermistor on pin temp3 M950 H1 C"0.out1" T1 ; create chamber heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang for chamber and set pwm M141 P0 H1 S0 R0 ; chamber heater 1 uses heater 1 M143 H1 S255 P0 T1 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S2 P"3.spi.cs0" Y"rtd-max31865" A"Primary Top" ; configure Primary sensor top as PT100 on pin spi.cs0 M950 H2 C"3.out6" T2 ; create Primary heater output on out3 and map it to sensor 2 M307 H2 A940 C810 D22 S1.0 B0 ; disable bang-bang for Primary and set pwm M143 H2 S480 P0 T2 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S3 P"3.spi.cs1" Y"rtd-max31865" A"Primary Middle" ; configure Primary sensor bottom as PT100 on pin spi.cs1 M950 H3 C"3.out7" T3 ; create Primary heater output on out4 and map it to sensor 3 M307 H3 A940 C810 D22 S1.0 B0 ; disable bang-bang for Primary and set pwm M143 H3 S480 P0 T3 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S4 P"4.spi.cs0" Y"rtd-max31865" A"Primary Nozzle" ; configure Primary sensor nozzle as PT100 on pin spi.cs0 M950 H4 C"4.out8" T4 ; create Primary heater output on out0 and map it to sensor 4 M307 H4 A795 C920 D10 S1.0 B0 ; disable bang-bang for Primary and set pwm M143 H4 S480 P0 T4 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S5 P"3.temp0" Y"PT1000" A"Mosquito 1" ; configure mosquito sensor top as PT1000 on pin 3.temp0 M950 H5 C"3.out0+out1" T5 ; create Primary heater output on out3 and map it to sensor 2 M307 H5 R2.364 K0.493:0.022 D7.12 E1.35 S1.00 B0 V24.1 ; disable bang-bang for Primary and set pwm M143 H5 S505 P0 T5 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition M308 S6 P"4.temp0" Y"PT1000" A"Mosquito 2" ; configure mosquito sensor top as PT1000 on pin 3.temp0 M950 H6 C"4.out0+out1" T6 ; create Primary heater output on out3 and map it to sensor 2 M307 H6 R2.364 K0.493:0.022 D7.12 E1.35 S1.00 B0 V24.1 ; disable bang-bang for Primary and set pwm M143 H6 S505 P0 T6 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition ; Heater Faults M570 H0 P1000 T15 R10 M570 H1 P1000 T15 R10 M570 H2 P1000 T15 R10 M570 H3 P1000 T15 R10 M570 H4 P1000 T15 R10 ; Accessories M950 F0 C"0.out7" ; create chassis fan 0 on relay M106 P0 S255 H-1 C"Chassis Fan" ; set fan 0 value, thermostatic control off M950 F1 C"0.out8" ; create chamber fan 1 on relay M106 P1 S0 H1 T50 C"Chamber Fan" ; set fan 1 value, thermostatic control from sensor 1 M950 F2 C"0.out2" ; create Primary pc fan 2 M106 P2 S0 H-1 C"Primary Fan" ; set fan 2 value, thermostatic control off M950 F3 C"1.out1" ; create mosquito pc fan 3 M106 P3 S0 H-1 C"Mosquito Fan" ; set fan 3 value, thermostatic control off M950 F4 C{global.vacZone1Pin} ; create bed vac valve 1 M106 P4 S0 H-1 C"Vacuum Zone 1" ; set fan 5 value, thermostatic control off M950 F5 C{global.vacZone2Pin} ; create bed vac valve 2 M106 P5 S0 H-1 C"Vacuum Zone 2" ; set fan 5 value, thermostatic control off M950 F6 C{global.vacZone3Pin} ; create bed vac valve 3 M106 P6 S0 H-1 C"Vacuum Zone 3" ; set fan 5 value, thermostatic control off M950 F7 C{global.vacZone4Pin} ; create bed vac valve 4 M106 P7 S0 H-1 C"Vacuum Zone 4" ; set fan 5 value, thermostatic control off M950 F8 C"2.out6" ; create door locks on relay M106 P8 S0 H1 T65 C"Door Locks" ; set fan 5 value, thermostatic control on M950 F9 C"2.out4" ; create radiator on relay M106 P9 S1 H2:3:4:5:6 T50 C"Radiator" ; set fan 8 value, thermostatic control on M950 F10 C"1.out4" ; create probe on relay M106 P10 S0 H-1 C"Probe" M950 F11 C"2.io1.out" ; create venturi valve was 1.out0 M106 P11 S0 H-1 C"Venturi" ; set fan 11 value, thermostatic control off M950 F12 C"4.out6" ; create head electronics fan M106 P12 S255 H-1 C"Head Fan 1" ; set fan 12 value, thermostatic control off M950 F13 C"4.out7" ; create head electronics fan M106 P13 S255 H-1 C"Head Fan 2" ; set fan 12 value, thermostatic control off M950 F14 C"1.out8" ; create yellow stack led M106 F14 S0 H-1 C"Yellow LED" ; set fan 14 value, thermostatic control off M950 F15 C"1.out7" ; create green stack led M106 F15 S0 H-1 C"Green LED" ; set fan 15 value, thermostatic control off M950 F16 C"1.out6" ; create yellow stack led M106 F16 S0 H-1 C"White LED" ; set fan 16 value, thermostatic control off M950 F17 C"1.out3" ; create yellow stack led M106 F17 S0 H-1 C"Beep" ; set fan 14 value, thermostatic control off ; Trigger Inputs M950 J0 C"2.io0.in" ; assign input J0 to 2.io0.in for emergency stop M581 P0 T0 S0 R0 ; configur external trigger, pin 0, trigger 0, inactive-active, any time M950 J1 C"2.io1.in" ; assign input J1 to 1.io1.in for pause button M581 P1 T1 S0 R1 ; configure external trigger, pin 1, trigger 1, inactive-active, during print ; Tools M563 P0 S"Primary" D0 H2:3:4 F2 ; define tool 0 as Primary, extruder 0, Heaters 2 3 4, Fan 2 M568 P0 R0 S0 ; set tool 0 active and standby temperatures to 0C G10 P0 X0 Y0 Z0 U0 V0 W0 ; set tool 0 axis offests M563 P1 S"Mosquito 1" D1 H5 F3 ; define tool 1 as Mosquito 1, extruder 1, Heaters 5, Fan 3 was H5:6 M568 P1 R0 S0 ; set tool 1 active and standby temperatures to 0C G10 P1 X0 Y0 Z{global.T1ZOffset} U0 V0 W0 ; set tool 1 axis offests M563 P2 S"Mosquito 2" D2 H6 F3 ; define tool 2 as Mosquito 2, extruder 1, Heaters 6, Fan 3 was H7:8 M568 P2 R0 S0 ; set tool 2 active and standby temperatures to 0C G10 P2 X0 Y0 Z{global.T2ZOffset} U0 V0 W0 ; set tool 2 axis offests ; Custom settings are not defined ; Miscellaneous G4 S2 M83 ; relative extruder moves
M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 MB6XD v1.0 or later FIRMWARE_DATE: 2022-11-30 19:41:59
Issue resolved. M106 commands used F parameter instead of P.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
