    does not completely finish the last layer of the print 3.5.0-b4
    Beta Firmware
    1.9k
    • Arminasundefined
      Arminas
      Strange printer behavior - does not completely finish the last layer of the print. Any ideas?photo_2023-08-02_09-42-54.jpg
      • chrishammundefined
        chrishamm administrators @Arminas
        @Arminas Firmware version? Please share the full G-code file.
        Duet software engineer
        Arminasundefined 1 Reply Last reply Reply Quote 0
        • Arminasundefined
          Arminas @chrishamm
          @chrishamm RRF 3.5.0-b4
          https://we.tl/t-Zt7V7z88Ji
          I have printed 3 same gcodes on same printer in a row, 2 came out great and the last one is shown in the picture above...
          • gloomyandyundefined
            gloomyandy @Arminas
            @Arminas What board is this running on? SBC or standalone? Have you printed anything since you had this problem, was it ok?
            • Arminasundefined
              Arminas @gloomyandy
              @gloomyandy duet 3 mini 5+, standalone.
              I had this problem with other part too a week ago, then everything seemed nice since today.
              • Phaedruxundefined Phaedrux moved this topic from 3D Printing General Chat
              • Arminasundefined Arminas referenced this topic
                dc42 administrators @Arminas
                Did DWC show the print as having finished (i.e.. status change from Printing to Idle and the heaters turned off), or did the machine stop moving but the status remain as Printing?
                If it happens again, please run M122 before doing anything else.
                Arminasundefined 3 Replies Last reply Reply Quote 0
                • Phaedruxundefined Phaedrux moved this topic from General Discussion
                • Arminasundefined
                  Arminas @dc42
                  @dc42 Most of the time, after the printing process, DWC shows that printing is paused and I have to press cancel the print, although it's finished, but heaters are turned off.
                  Today it happen again, and even worse. I was looking at the last layer being finished, and couple of seconds before the end, print bed moved up very fast and crashed into the part, melting the hole into the part with hot nozzle.... Luckily, I was standing next to the printer and turned it off as fast as I could.
                  Diamondbackundefined 1 Reply Last reply Reply Quote 0
                  • Arminasundefined
                    Arminas @dc42
                    @dc42 M122:
                    M122
                    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
                    Board ID: U51SX-F396U-D65J0-40KMW-M603Z-ZFNKD
                    Used output buffers: 1 of 40 (18 max)
                    Static ram: 102996
                    Dynamic ram: 122548 of which 0 recycled
                    Never used RAM 16512, free system stack 188 words
                    Tasks: NETWORK(1,ready,46.8%,240) HEAT(3,nWait,0.1%,327) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,939) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,3.7%,116) MAIN(1,running,46.6%,704) IDLE(0,ready,0.1%,29) AIN(4,delaying,2.6%,266), total 100.0%
                    Owned mutexes:
                    Last reset 02:19:32 ago, cause: power up
                    Last software reset at 2023-07-25 21:46, reason: User, Gcodes spinning, available RAM 13112, slot 2
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                    Error status: 0x00
                    MCU revision 3, ADC conversions started 8372702, completed 8372702, timed out 0, errs 0
                    MCU temperature: min 34.5, current 34.8, max 41.0
                    Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                    Events: 0 queued, 0 completed
                    Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 40203, writes 11, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 40203, writes 11, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 40204, writes 10, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 40203, writes 10, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 40203, writes 11, timeouts 0, DMA errors 0, CC errors 0
                    Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 40203, writes 11, timeouts 0, DMA errors 0, CC errors 0
                    Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 40203, writes 10, timeouts 0, DMA errors 0, CC errors 0
                    Date/time: 2023-08-21 22:03:31
                    Slowest loop: 7.11ms; fastest: 0.16ms
                    === Storage ===
                    Free file entries: 20
                    SD card longest read time 3.6ms, write time 0.0ms, max retries 0
                    DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                    no step interrupt scheduled
                    === DDARing 0 ===
                    === DDARing 1 ===
                    Heater 1 is on, I-accum = 0.0
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    File2 is idle in state(s) 0
                    Queue2 is idle in state(s) 0
                    Q0 segments left 0, axes/extruders owned 0x0000803
                    Code queue 0 is empty
                    Code queue 1 is empty
                    === CAN ===
                    Messages queued 75351, received 0, lost 0, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 41863/0/0
                    Tx timeouts 0,0,41862,0,0,33487 last cancelled message type 4514 dest 127
                    === Network ===
                    Slowest loop: 15.28ms; fastest: 0.00ms
                    Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                    HTTP sessions: 1 of 8
                    = WiFi =
                    Interface state: active
                    Firmware version 1.26
                    MAC address f0:08:d1:03:81:a2
                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 24792
                    WiFi IP address 192.168.32.177
                    Signal strength -45dBm, channel 0, mode 802.11n, reconnections 0
                    Clock register 00002002
                    • Arminasundefined
                      Arminas @dc42
                      @dc42 Little update - once the part is done, DWC shows status "Printing", but heaters are turned off.
                        gloomyandy @Arminas
                        @Arminas Can you capture a M122 output when it is in that state?
                        • Arminasundefined
                          Arminas @gloomyandy
                          @gloomyandy I don't think so. It happens not every time and I am not sure if I want to wait for the next crash, it might damage my printer and products, so I am not willing to risk with my customers parts. I have downgraded to RRF 3.4.6, will see if the problem re-occurs or not. But if it will, I will definitely capture M122 output.
                          blt3dpundefined 1 Reply Last reply Reply Quote 0
                          • blt3dpundefined
                            blt3dp @Arminas
                            I noticed this same symptoms. Job would complete and complete all my end gcode, heaters would be off, head positioned as requested. But web interface would still say printing. I noticed that I’d I closed my browser, cleared the cache with just google loaded, then launched dwc and it showed normal.
                            My 3D Printing YouTube Channel
                            Better Living Through 3D Printing
                            Follow me on Instagram and Twitter
                            Instagram
                            Twitter
                              dc42 administrators @blt3dp
                              @blt3dp @Arminas I have created this Github issue https://github.com/Duet3D/RepRapFirmware/issues/899.
                              dc42 created this issue in Duet3D/RepRapFirmware
                              closed Print jobs sometimes fail to complete #899
                              Arminasundefined 1 Reply Last reply Reply Quote 1
                              • Arminasundefined
                                Arminas @dc42
                                @dc42 Quick update - after downgrading to RRF 3.4.6, this problem does not occur anymore. So I guess it has something to do with a firmware.
                                  @Arminas have you tried 3.5.0-rc.1 ? I had a similar issue with beta 4 occasionally but so far not with rc1. One of the bugs we fixed in rc1 may have been causing it.
                                  • Arminasundefined
                                    Arminas @dc42
                                    @dc42 not yet. I will do that next week.
                                      @Arminas thanks, that would be helpful.
                                      Arminasundefined 2 Replies Last reply Reply Quote 0
                                      • Arminasundefined
                                        Arminas @dc42
                                        @dc42 I have upgraded the firmware to 3.5.0-rc.1 and during the printing process, some strange movement on the outer perimeter occurred again (not at every layer, just for the couple layers in different position. I did not wait for the part to finish, I pressed Pause and typed M122 (don't know if it works that way to see if anything is strange):
                                        M122
                                        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1 (2023-08-31 16:16:56) running on Duet 3 Mini5plus WiFi (standalone mode)
                                        Board ID: ZNS47-R396U-D65J0-40KM0-MR03Z-H3B3X
                                        Used output buffers: 1 of 40 (19 max)
                                        Static ram: 102836
                                        Dynamic ram: 121740 of which 0 recycled
                                        Never used RAM 12976, free system stack 128 words
                                        Tasks: NETWORK(2,nWait,12.5%,228) HEAT(3,nWait,0.1%,329) Move(4,nWait,2.0%,240) CanReceiv(6,nWait,0.0%,939) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,1.3%,108) MAIN(1,running,82.8%,700) IDLE(0,ready,0.5%,29) AIN(4,delaying,0.9%,264), total 100.0%
                                        Owned mutexes: WiFi(NETWORK)
                                        Last reset 00:52:39 ago, cause: power up
                                        Last software reset at 2023-09-23 12:52, reason: User, Gcodes spinning, available RAM 13560, slot 1
                                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                        Error status: 0x00
                                        MCU revision 3, ADC conversions started 3159303, completed 3159302, timed out 0, errs 0
                                        MCU temperature: min 28.8, current 33.5, max 35.1
                                        Supply voltage: min 23.5, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
                                        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 25001, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 25001, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 25002, writes 12, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 25002, writes 12, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 25001, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 25001, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 25004, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2023-09-23 13:59:16
                                        Slowest loop: 219.42ms; fastest: 0.10ms
                                        === Storage ===
                                        Free file entries: 18
                                        SD card longest read time 8.8ms, write time 2.1ms, max retries 0
                                        DMs created 83, segments created 42, maxWait 29924ms, bed compensation in use: mesh, height map offset 0.000, ebfmin -1.00, ebfmax 1.00
                                        Moves shaped first try 3129, on retry 1088, too short 14104, wrong shape 10449, maybepossible 1115
                                        === DDARing 0 ===
                                        Scheduled moves 34591, completed 34591, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                                        === DDARing 1 ===
                                        Heater 0 is on, I-accum = 0.1
                                        Heater 1 is on, I-accum = 0.4
                                        Q0 segments left 0, axes/extruders owned 0x0000807
                                        === CAN ===
                                        Messages queued 28432, received 0, lost 0, boc 0
                                        Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 15797/0/0
                                        Tx timeouts 0,0,15796,0,0,12634 last cancelled message type 30 dest 127
                                        === Network ===
                                        Slowest loop: 183.65ms; fastest: 0.00ms
                                        === WiFi ===
                                        Firmware version 1.25
                                        MAC address f0:08:d1:03:76:dc
                                        Module reset reason: Power up, Vcc 3.34, flash size 2097152, free heap 26608
                                        WiFi IP address 192.168.32.190
                                        Signal strength -59dBm, channel 0, mode 802.11n, reconnections 0
                                        P.S. - I am printing in high speed this time, 200 mm/s, I don't think that speed has something to do with it, but just in case.
                                        I can see and hear that extruder wheel is doing something strange on the corner, movement is not smooth and it extrudes more material than it should (it is not a start point). Don't mind the infill, I am experimenting with fast printing speed.
                                        Also, Input Shaping is activated.
                                        • Arminasundefined
                                          Arminas @dc42
                                          @dc42 Downgraded to 3.4.6 again, no issues. Input Shaper activated, same speed. I don't know if something is wrong with my setup/config, but 3.5.0 rc1 does not work for me šŸ˜„
                                          • A Former User?
                                            A Former User @Arminas
                                            @Arminas You seem to have had the same problem as I am having.
                                            I noticed when I looked over the print, the blobs were caused by the printhead stopping for a fraction of a second, so residual pressure in the hotend was extruding plastic on the one area, causing the blob.
                                            https://forum.duet3d.com/topic/33692/input-shaper-causing-stutters-and-blobs-on-curves-rrf3-5-0-rc-1/1
