Expanding Duet3D mini 5+
Can I use DueX5 as an expansion for Duet3D mini 5+?
@dc42 can you give me any suggestions, Sir? -
No the Duex5 will only work with a Duet 2. In order to expand the Duet 3 you have other options via its CANBUS connection. Depending on what you need more of, you can add a single toolboard, or a 2 driver expansion, or even a second mini5+.
You can see a list of the expansion options here: https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family
undefined Andrew_15 has marked this topic as solved
undefined Andrew_15 has marked this topic as unsolved
