Solved Reset on homing z axis with a z probe
We are using a e3d toolchanger based printer with a Duet3d 6HC and a 3HC expansion board with web control. All on version 3.5.0beta4. The problem is not present in 3.4.6 (or 3.4.5).
When configuring the z axis endstop to be a z probe and then subsequently run a G1 H1 (or even H4) we observe a reset. Further, after the reset, the expansion board is not detected anymore.
Both the z axis stepper and the probe are connected to the mainboard.
Relevant section of config.g
M558 P5 C"io2.in" K0 H3 F360 T20000 M574 Z1 S2 K0
When we then run z homing we observe reset on the G1 H1 command (tested using the console)
G91 G1 H1 Z-200 F2000
M119 gives expected outputs and detects the z probe state change.
If we define the switch as a regular endstop, z homing functions function. But we require a z probe.
M574 Z1 S1 P"io2.in"
@ateRstones Please post the output from running M122
@gloomyandy here you go: m122-homing-problem.txt
sorry for the late response, I'm only infreqently near the machine atm
@ateRstones said in Reset on homing z axis with a z probe:
M574 Z1 S2 K0
That's not quite right.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m574-set-endstop-configuration
S2 = Z probe (when used to home an axis other than Z)
But it sounds like you're actually trying to use it with the Z axis.
To configure a z probe using a swithc, use M558 and G31 to configure the switch as a probe and use a G30 command in your homing files to use the probe. Leave out the M574 Z line entirely. It's not needed when configuring a probe for Z.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type
You'd want M558 P8 for a switch.
@ateRstones is this resolved?
@dc42 the answers were able to resolve the problem, thanks everyone for the help!
