    Emergency reset
    • mrwaug
      mrwaug last edited by
      i was about 3hrs in a print job, when i made an adjustment to the speed factor. at that moment, i was shown a message that the emergency stop had been activated. here is the m122 file
      , i am still running 1.19.2 because it seemed like the newer versions were plagued with reset, disconnects, and ajax problems. Do i need to bite the bullet and upgrade to the latest and greatest versions
      M122
      Used output buffers: 3 of 32 (5 max)
      RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
      Board ID: 08DAM-9K9K2-NGNS0-7JTD2-3S46M-KP2RJ
      Static ram used: 21176
      Dynamic ram used: 96032
      Recycled dynamic ram: 1576
      Stack ram used: 1304 current, 4880 maximum
      Never used ram: 7408
      Last reset 00:00:53 ago, cause: software
      Last software reset reason: User, spinning module GCodes, available RAM 3192 bytes (slot 4)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 44.0, current 45.1, max 45.6
      Supply voltage: min 12.4, current 12.5, max 12.6, under voltage events: 0, over voltage events: 0
      Driver 0: stalled standstill
      Driver 1: stalled standstill
      Driver 2: standstill
      Driver 3: stalled standstill
      Driver 4: standstill
      Date/time: 2017-12-06 10:27:05
      Slowest main loop (seconds): 0.005385; fastest: 0.000034
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Bed heater = -1, chamber heater = -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19.2
      WiFi MAC address 5c:cf:7f:f7:de:c3
      WiFi Vcc 3.16, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 39616
      WiFi IP address 10.0.0.61
      WiFi signal strength -50dBm
      Reconnections 0
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      650X350 Delta. Duet wifi, IR z prob, E3d volcano.
        I'm sorry you lost your print. Were you adjusting the speed factor from DWC, PanelDue, or some other input?
        • DjDemonD
          DjDemonD last edited by
          The 1.20beta11 build is solid, have no fear - upgrade.
          www.precisionpiezo.co.uk
          • mrwaug
            Quote Answer Report
            I was using DWC to increase the speed 10% faster. The other strange thing that it has done since there 1.19 upgrade, is when I make a change to the config.g file, it asked if I want to reboot, when I do, I get a Ajax error and I have to reconnect. It really isn't an issue, but just something new.
