    Writing variables to a file, problems with nested echo commands
    Gcode meta commands
    • ComedianTF2undefined
      ComedianTF2
      Firmware: 3.5.0-beta.4
      Duet web control: 3.5.0-beta.4
      I am working on a script to write several global variables to a file, per a series of messages sent to a user, so the user can get the right set of variables for their printer after executing the script.
      The first part of the code (line 1 through 15) work well, and in the resulting config_globals.g, the first parameters (version 1 or version 2) are set correctly
      However the second set of parameters (printer model 1 or 2) are not set at all, it seems as if nestling the echo commands that deep is causing problems.
      M30 "0:/sys/test/config_globals.g"
      M28 "0:/sys/test/config_globals.g"
      M29
      M291 T0 S4 R"Welcome" P"Welcome to your Printer. Please select the version of printer you have" K{"V1","V2"}
      	if input = 0
      		M291 S3 R"Version V1" P"According to this, you have a V1 printer. Press OK to confirm, or cancel to re-start"
      		echo >"0:/sys/test/config_globals.g" "if !exists(global.config_version)"
      		echo >>"0:/sys/test/config_globals.g" "   global version = 1"
      		global version = 1
      	if input = 1
      		M291 S3 R"Version V2" P"According to this, you have a V2 printer. Press OK to confirm, or cancel to re-start"
      		echo >>"0:/sys/test/config_globals.g" "   global version = 2"
      		global version = 2
      if global.version = 1
      	M291 T0 S4 R"V2 to V3" P"Do you have a A model or a B model" K{"A model","B model"}
      		if input = 0
      			echo >>"0:/sys/test/config_globals.g" "   global printer-model = 1"
      		if input = 1
      			echo >>"0:/sys/test/config_globals.g" "   global printer-model = 2"
      elif global.version = 2
      	M291 T0 S4 R"V2 to V3" P"Do you have a C model or a D model" K{"C model","D model"}
      		if input = 0
      		if input = 1
      The output of this file, selecting first version 1 and then printer model 1 is this:
         global version = 1
      However the expected and desired code is:
         global version = 1
      Executing the echo commands separately does work, so I am not sure why the commands are not working when used in this fashion.
      As another test, I also created two files named version1.g and version2.g, that contained the sub-scripts. In that case, the echo commands correctly wrote the global parameters to the config_globals.g
      	M98 P"0:/sys/test/version1.g"
      	M98 P"0:/sys/test/version2.g"
      version1.g example:
      	if input = 0
      		;global printer-model = 1
      	if input = 1
      		echo big120x
      		;global printer-model = 2
        dc42 administrators @ComedianTF2
        @ComedianTF2 what is this line supposed to do?
        echo big120x
        It's not valid and may cause execution of the macro to stop.
        ComedianTF2undefined 1 Reply Last reply Reply Quote 0
          ComedianTF2 @dc42
          @dc42 a leftover from trying to diagnose the problems, I re-wrote the macro to be significantly simpler from the one I was working on, but the problems remained.
          When removed it still doesn't work
            @ComedianTF2 printer-model isn't a valid variable name. Use printer_model instead.
              ComedianTF2 @dc42
              @dc42 The problem is not in the variable name, I tested it and it did not work with the following script:
              M29
              	if input = 0
              		global version = 1
              	if input = 1
              		global version = 2
              		if input = 0
              			echo >>"0:/sys/test/config_globals.g" "   global printer_model = 1"
              		if input = 1
              			echo >>"0:/sys/test/config_globals.g" "   global printer_model = 2"
              		if input = 0
              		if input = 1
              That outputs (when choosing V1 and model A)
                 global version = 1
              However this combination of scripts does work:
              M29
              	if input = 0
              		;global version = 1
              	if input = 1
              		;global version = 2
              elif global.generation = 2
              	if input = 0
              	if input = 1
              	if input = 0
              	if input = 1
                 global version = 1
              I don't see a good reason why the script with everything contained in one file would not work, but that same script just split out over three files does work as it should
                @ComedianTF2 I confirm that your original script doesn't work. I changed it to the following, which works:
                if fileexists("0:/sys/test/config_globals.g")
                if input = 0
                	global version = 1
                if input = 1
                	global version = 2
                	if input = 0
                	if input = 1
                	if input = 0
                	if input = 1
                I think it was indenting the if-blocks more than the preceding M291 command that was causing the problem. I have created Github issue https://github.com/Duet3D/RepRapFirmware/issues/897.
                dc42 created this issue in Duet3D/RepRapFirmware
                closed Extra indentation causes script not to work #897
                ComedianTF2undefined 1 Reply Last reply Reply Quote 1
                  ComedianTF2 @dc42
                  @dc42 Thanks for that.
                  Good to know that the choice selection for the M291 T0 S4 does not need to be indented, that makes a large difference and with that I should be able to get everything in a single file
