    fatal error: MessageFormats.h
    Firmware developers
    • Nemo
      Nemo last edited by
      Hello everyone, I am compiling RepRapFirmware version 3.4. For the Duet 3 Mainboard 6HC, once everything worked, but I changed the computer and now this error comes out. Please tell me how to fix this.
      Thank you very much!!!
        dc42 administrators @Nemo last edited by
        @Nemo add project DuetWiFiSocketServer to your Eclipse workspace as per the build instructions. You don't need to build it but it must be present.
        Nemo 1 Reply Last reply Reply Quote 0
        • Nemo
          Nemo @dc42 last edited by
          @dc42 Hello, in this instruction
          https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware#instructions-for-building-under-windows
          It is said that for the Duet 3 MB6HC payment you do not need to add DuetWiFiSocketServer.
          Following your advice, I added DuetWiFiSocketServer to the space. The result is this. I am attaching photos of errors and environment settings.
            dc42 administrators @Nemo last edited by dc42
            @Nemo your photos are so out of focus or the resolution so low that the text is impossible for me to read.
            Duet 3 MB6HC supports an optional wifi module since hardware version 1.02, as a result DuetWiFiSocketServer is now needed to be in the workspace for RRF to be compiled for it.
                dc42 administrators @Phaedrux last edited by
                @Phaedrux thanks.
                @Nemo I think you are using an old version of project DuetWiFiSocketServer. Use the dev branch of that project.
                • Nemo
                  @dc42 said in fatal error: MessageFormats.h:
                  It worked, I used the master branch, and when I selected DEV it compiled. There are 2 errors, but as I understand it, this is no longer a problem, since compilation of this file is not necessary.
