    3.5.0rc1 input shaping poor quality
    Beta Firmware
    • Adrian52undefined
      Adrian52
      Printing a model with protruding detail does not work well on my setup with 3.5rc1:
      alt text - lots of surface blebs, and while printing, movement is quite jerky.
      The same gcode with 3.4.6 looks fine:
      With input shaping set to "none" on 3.5rc1, the result looks like the 3.4.6 picture. In both cases, the movement on the external loops was smooth and regular.
      I have been using ei3 @30hz 0.1damping. Kossel delta, stand alone duet2wifi ver1.01.
        dc42 administrators @Adrian52
        @Adrian52 the rc1 release applies IS to short moves that earlier releases didn't apply it to. You could try increasing the minimum acceleration parameter in the M593 command to restrict the reduction of acceleration permitted to apply IS.
        Adrian52undefined 1 Reply Last reply Reply Quote 0
        • Adrian52undefined
          Adrian52 @dc42
          @dc42 Thank you - that seems to work. A value of 100 seems to give a nice result on this model.
          • Adrian52undefined Adrian52 referenced this topic
