    The reason is that the M 587 command is too long
    • PICHANDESU
      PICHANDESU last edited by
      The following error appears.
      Executing config.g … Error: G-Code buffer 'daemon' length overflow
      The reason is that the M 587 command is too long.
      M587 S"MyNetgwork----" P"longpassword--------------------" I192.168.1.121 J192.168.1.1 K255.255.255.0
      Splitting and sending M587 commands does not seem to be effective.
      exp)
      M587 P"longpassword--------------------"
      M587 I192.168.1.121
      M587 J192.168.1.1
      M587 K255.255.255.0
      Is there a way to split commands and send them?
      FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20RC1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-08
        Currently there is no way to split the command. I will increase the maximum command length in 1.20RC2, or else allow the command to be split. How many characters long is the command line that you want to use?
        • PICHANDESU
          Thank you for your support.
          The required number of characters is 102 characters, but it is OK if you have a little more than 110 characters to see the margin.
          Please allow commands to be split.
          • gowen
            gowen last edited by
            That would explain a problem I was having. My WiFi key is 41 characters long. I set up a second access point with a shorter ssid and key. Time to upgrade to 1.20 I think.
              I increased the maximum command length to 160 characters in the 1.20RC2 builds for the generation 2 Duets.
