    Setting up ir probe on latest firmware missing pin name
    IR Height Sensor
    • ageisundefined
      ageis
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet Ethernet 1.02 or later
      Hi I have upgraded my bed to the one with removable steel sheet.
      Hence I probably should recalibrate my z height sensor.
      However following David's instructions on his blog gives me an error message about a missing pin name.
      M558 P1
      screenshot
      ageisundefined 1 Reply Last reply Reply Quote 0
      • ageisundefined
        ageis @ageis
        @ageis
        Going to document it here in case someone runs into this problem
        M558 P1 C"zprobe.in+zprobe.mod"
        dc42undefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @ageis
          @ageis that blog entry hasn't been updated for many years. Documentation on connecting the IR probe (and other TYPES F z PROBE) is at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting.
          You don't need zprobe.mod for the IR sensor, it's only needed for the dumb modulated IR sensors supplied with later Ormerod and Huxley kits supplied by RepRapPro.
