    G38.2 much less precise than G30 and moving wrong axes (Bug?)
    Using Duet Controllers
    • NeoDueundefined
      NeoDue
      I still need to doublecheck that, but for some reason the values a G38.2 Z probe move prints out seem to be quite a bit less precise than the ones a G30 z probe moves create - so far, testing created variances in hundreths of a millimeter for G30, compared with tenths of a millimeter for G38.2. Is that intentional or a bug in firmware 3.5.0 rc1?
      The only reason I use G38.2 is that G30 moves keep creating messages on the PanelDue which disturb the ones I create.
      NeoDueundefined 1 Reply Last reply Reply Quote 0
      • NeoDueundefined
        NeoDue @NeoDue
        Update: I tested this now with the following macro:
        ; Variables
        global Druckplattendicke = 5        ; defined in my config.g, just added here for clarity
        var Startmesshoehe = 2
        var Wartezeit = 500			; Millisekunden zusätzlich zur Dauer der Messung geändert
        G28 							; Homing
        T1 P0 						;activate right print head
        ; remove glass plate to get access to sensor contacts on bed
        G1 H2 Z180 F6000
        M400
        M291 S2 P"remove the glass plate!" R"bed leveling"
        ; heat up heads and bed
        ; G1 H2 Z{move.axes[2].max} F6000
        M140 S60 						; bed: 60°Cn
        M568 P1 S220				; Hotend 2:  220°C
        M116							; wait
        ; clean print head
        G1 H2 U{move.axes[3].max-50} F3000
        M400
        M291 S2 P"thoroughly clean the print head and the bed contacts" R"bed leveling"
        G1 H2 U{move.axes[3].max} F3000 	; back to parking pos.
        G1 H2 Z0 F6000						; move bed up - contact height is -5mm (glass thickness)
        ; measure distance with G30
        G1 H2 U115 Y-94 F3200					; move to contact
        M400								; wait
        G1 H2 Z{-global.Druckplattendicke + var.Startmesshoehe} F6000	; move bed closer to nozzle
        M400
        while iterations <=6
        	G4 P{var.Wartezeit}			; wait
        	G30 S-1 K1					; measure Z with the right hotend
        	G1 H2 Z{move.axes[2].machinePosition + var.Startmesshoehe} F3000	; lift nozzle
        ; measure distance with G38.2
        	G38.2 Z-7 K1				; measure Z with the right hotend
        	echo {move.axes[2].machinePosition}
        	T0 P0
        	G1 X-175 F3000				; why the hell does the G38.2 command above move the X
        axis?? Move the head out of the way where it belongs for now <-- does not work either. Why?
        	T1 P0
        ; finish
        G1 H2 Z5 F100						; move bed back to safe distance for XY moves
        Result:
        • The G30 probes vary +/- 0,003 mm, with an offset around 0,02 mm between measurement cycles which is most likely caused by the XY gantry.
        • The G38.2 results vary up to +/- 0,1 mm around what was measured by G3 before (the variance itself varies greatly between measurement cycles), and the G38.2 command moves the X axis together with the Z axis, which I do not understand at all. (By the way, the printer is a typical cartesian IDEX printer running RRF 3.5.0rc1 on a Duet 3 6HC - one motor for X, one for Y, one for Z and one for U. Thus, just a simple M669 K0 in the config.g, nothing fancy...)
        Edit: I also tested if that precision issue might be caused by the other hotend moving (I unplugged the motor for that since I could not get it to stop moving). Result: no, the quality of G38.2 does not get better...
        2nd Edit: even if I disable the X stepper with M18, G38.2 moves it when it should move Z only - and that happens without updating its position 😲
        • NeoDueundefined
          NeoDue
          And another question about this topic: with G38.2 being too unprecise (and moving axes it should not) and G30 creating messages on the PanelDue I do not want - is there any other way to do a z probe without getting a popup on the PanelDue? (in case someone asks about the reason, look here - I want to recreate the "guided leveling" the Snapmaker J1 has)
          Conditional Gcode with "while sensors.probes[1].value[0] == ..." does not work because of the channel logic @dc42 noted here.
          Edit: in case it is needed, here is the axes / tools definition part of my config.g:
          ; general
          M451								; FDM printer
          M669 K0 							; cartesian printer
          M111 S0 							; Debugging off
          G21 								; units: millimeters
          G90 								; absolute coordinates...
          M83 								; ... except for the extruder
          M555 P1 							; firmware compatibility RepRapFirmware
          M200 D1.75 							; filament diameter 1,75mm for all extruders
          ; global variables
          global Druckplattendicke = 5.00 	; print plate thickness
          global Filament_X_retract = false   ; used for tool switch macros
          global Filament_U_retract = false   ; used for tool switch macros
          ; PanelDue
          M575 P1 S1 B115200
          ; drivers
          M569 P0.0 S0 F4 Y1:2 D3 H94 V94 ; DRIVER_0 (X)
          M915 P0.0 T94
          M569 P0.1 S1 F4 Y1:2 D3 H94 V94 ; DRIVER_1 (U)
          M915 P0.1 T94
          M569 P0.2 S1 D3 H310 V310		; DRIVER_2 (Z)
          M915 P0.5 T310
          M569 P0.3 S0 F4 Y1:2 D3 H94 V94 ; DRIVER_3 (Y)
          M915 P0.3 T94
          M569 P0.4 S0 D3 H310 V310		; DRIVER_2 (E1)
          M915 P0.5 T310
          M569 P0.5 S1 D3 H310 V310		; DRIVER_3 (E2)
          M915 P0.5 T310
          ; axes and extruders
          M584 X0.0 U0.1 Y0.3 Z0.2 E0.5:0.4			; map drivers to axes
          M350 E64:64 Z16 I0
          M350 X16 U16 Y16 I1
          M92 X80 U80 Y80 Z1600 E138.58:138.58 S16
          M566 X240 U240 Y240 Z100 E100:100
          M203 X21000 U21000 Y21000 Z600 E4800:4800
          M201 X8000 U8000 Y8000 Z500 E5000:5000
          M906 X1000 U1000 Y1400 Z1000 E800:800 I95
          M84 S30
          M915 X U Y S20 F1 R2                        ; Stallguard
          ; coordinates
          M208 X-175 Y-101 Z0 U-151 S1 		; min
          M208 X151 Y101 Z209 U175 S0 		; max
          M563 S"Hotend 1" P0 D0 H1 F0
          G10 P0 X0 Y0 Z0
          M568 P0 R0 S0
          M563 S"Hotend 2" P1 D1 H2 F1 X3
          G10 P1 X0 Y0 Z0
          • fcwiltundefined
            fcwilt
            My reading of the documentation on G30 and G38.2 suggests they are intended for very different purposes.
            Is the issue with the PanelDue critical?
            • NeoDueundefined
              NeoDue @fcwilt
              @fcwilt you are right, but I admit I expected a probe move have a similar accuracy in all cases. And there is no remark at G38.2 that limits it to CNC use.
              The PanelDue issue is critical in that way that it breaks the display of motion messages I wrote to recreate the graphic leveling tools of the Snapmaker J1.
              Sadly, neither @Phaedrux nor @dc42 had this obstacle in mind when I posted my initial question if such a recreation with the corresponding display is possible... everything else works (even if it is a bit fincky to tune the display timing vs. the measurement times since you cannot update a message in the PanelDue instead of creating a new one), it is just that one command.
              • fcwiltundefined
                fcwilt @NeoDue
                @NeoDue said in G38.2 much less precise than G30 and moving wrong axes (Bug?):
                Do you have any programming skills?
                The Duets are able to send Telnet messages to a remote device, like a computer.
                Perhaps that feature could be used to send the needed information to an application running on a computer to obtain the desired display.
                • NeoDueundefined
                  NeoDue @fcwilt
                  @fcwilt No, sorry... Some basic things such as batch programs or conditional gcode is okay, but everything else is over my head - otherwise I would have already tried to compile my own version or add a parameter to G30 in Github...
                  Thus, I think that would require much more than I can do. Apart from that, I have to admit I don't really like having to switch between two displays.
                  • NeoDueundefined NeoDue referenced this topic
