    Dead links to dozuki
    Documentation
    • nikschaundefined
      nikscha
      Hi all,
      The first two links on https://docs.duet3d.com/User_manual/Tuning/Triggers
      point to the inactive dozuki.
      Stay in school
      • nikschaundefined nikscha marked this topic as a question
        droftarts administrators @nikscha
        @nikscha Thanks. I've removed the links. All the info from Dozuki was copied into the new page, so there shouldn't be anything missing, it was just to quote the source. You can find the original on the Internet Archive, if you want to look at it, though it is not updated for RRF 3 or Duet 3.
        For the original versions, see https://web.archive.org/web/20220701070449/https://duet3d.dozuki.com/Wiki/Using_M581_-_External_Triggers_and_Building_a_Control_Panel
        and https://web.archive.org/web/20230209052754/https://duet3d.dozuki.com/Guide/Water+flow+sensor+failsafe/49
        nikschaundefined 1 Reply Last reply Reply Quote 1
        • droftartsundefined droftarts has marked this topic as solved
        • nikschaundefined
          nikscha @droftarts
          @droftarts Much appreciated, thank you!
          Stay in school
