    CAN I use the PWM on OUT 9 to control the effective voltage
    • Behrouz-AKTundefined
      Behrouz-AKT
      How do I create a PWM duty cycle on the VOUTLC2 output on "Out 9" connector on the 6HC board . can some one please direct me to the appropriate documentation.
      In essence I am trying to control an outx pin to have a duty cycle to drive a DC motor to vary the effective voltage. Thanks for your help.
      • niocio01undefined
        niocio01
        If I get you question right you should be able create a "Output" binding.
        Have a look at Connecting DC motors in the docs.
        Make sure you read and understand the "Cautions" part and add a flyback diode, if necessary.
        Behrouz-AKTundefined 1 Reply Last reply Reply Quote 0
          Behrouz-AKT @niocio01
          @niocio01 Thanks that is exactly what i was looking for.
