    Set up prusa pinda 2 probe
    • ageisundefined
      ageis
      I have ordered myself a pinda 2.probe. This probe has four wires instead of three.
      I was wondering how do I hook it up to the duet Ethernet and how to configure it so that it uses the built in thermistor and functions as a z probe?
        droftarts administrators @ageis
        @ageis This page seems to have the best description of the wiring https://www.3dpedie.cz/en/manuals/p.i.n.d.a-v2/
        BLACK > Output signal from the probe
        BLUE > GND, or ground
        BROWN > +5V
        WHITE > Temperature sensor output
        I think you have a Duet 2 Ethernet? You'll need to split out the +5V (Brown) and temperature sensor output (White) and connect them to +5V (the Z probe header only has 3V) and a thermistor input respectively. Black and Blue can connect to the appropriate connections on the Z probe header.
        For configuration, define the probe with M558, the thermistor with M308 and the probe offsets and compensation with G31. There's an example in the Gcode Dictionary in the G31 entry: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status
        ; RRF 3.3 and later example of probe with thermistor and temperature compensation
        M558 P8 C"io2.in" H1 F1000 T6000 A3              				  ; Prusa PindaV2 Endstop
        M308 S2 P"temp2" A"Pinda V2" Y"thermistor" T100000 B3950  ; Prusa PindaV2 Thermistor
        G31 P500 X23 Y5 Z1.1 S21 H2 T0.02                         ; Nozzle offset - Smooth Sheet
        The above is for Duet 3, so change the input pins to the ones you are using (M558 C parameter, M308 P parameter).
