Solved [3.5.0-rc1] daemon.g keeps running after renaming
Hi all,
my daemon.g looks like this:
while true G4 P2000 echo "test"
when remaning it to daemon1.g it keeps running:
changing daemon1.g to
while true G4 P2000 echo "test2"
yields
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.01 (SBC mode) Board ID: 08DJM-9P63L-DJ3S0-7J1F8-3S86T-TBJZ8 Used output buffers: 1 of 40 (22 max) === RTOS === Static ram: 154852 Dynamic ram: 90516 of which 1452 recycled Never used RAM 92980, free system stack 122 words Tasks: SBC(2,ready,1.1%,422) HEAT(3,nWait,0.0%,323) Move(4,nWait,0.4%,214) CanReceiv(6,nWait,0.1%,771) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,349) TMC(4,nWait,8.5%,59) MAIN(2,running,89.8%,137) IDLE(0,ready,0.1%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 01:10:35 ago, cause: power up Last software reset at 2023-10-16 15:38, reason: User, Expansion spinning, available RAM 92980, slot 0 Software reset code 0x6012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 20.1, current 38.5, max 38.9 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/1572/1248, gc cycles 1 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 120, reads 42313, writes 51 timeouts 0 Driver 1: standstill, SG min 0, mspos 408, reads 42313, writes 51 timeouts 0 Driver 2: standstill, SG min n/a, mspos 8, reads 42348, writes 16 timeouts 0 Driver 3: standstill, SG min n/a, mspos 8, reads 42348, writes 16 timeouts 0 Driver 4: standstill, SG min n/a, mspos 8, reads 42353, writes 11 timeouts 0 Driver 5: standstill, SG min 0, mspos 856, reads 42321, writes 43 timeouts 0 Date/time: 2023-10-18 10:41:22 Slowest loop: 67.45ms; fastest: 0.05ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 39, maxWait 701455ms, bed compensation in use: mesh, height map offset -0.016, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 29069, completed 29069, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 84], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 Heater 4 is on, I-accum = 0.2 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2* is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x10000003 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 93461, received 237613, lost 0, boc 0 Longest wait 56ms for reply type 6041, peak Tx sync delay 536, free buffers 50 (min 49), ts 21178/21177/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 36389/36389 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:16:31) Daemon: >> Doing macro daemon.g, started by system Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1 Full transfers per second: 1.54, max time between full transfers: 83.9ms, max pin wait times: 67.7ms/8.5ms Codes per second: 0.84 Maximum length of RX/TX data transfers: 5684/2152
@nikscha yes it will keep running until the file terminates. In your case it never will because of the "while true" loop.
The usual solution is to use a global variable to control it:
if !exists(global.runDaemon) global runDaemon=true while global.runDaemon ...
Then you can send
set global.runDaemon=false
from the console to stop the daemon. -
@dc42 I see, I expected the file to be "reloaded" after saving and then not being found afterwards because of the renaming. Thank you for the solution!
